[GRASS-user] r.in.gdal for importing categorical ArcGIS binary rasters
Nuno Sá
nunocesardesa at gmail.com
Thu Feb 13 02:58:30 PST 2014
Out of the box:
Import it in R and save it as a Tiff - use GRASS to open this tiff. Maybe
it works ;P
On 13 February 2014 10:50, Benjamin Ducke <benducke at fastmail.fm> wrote:
> Ouch. I am beginning to suspect that the ESRI "field"
> concept for raster layers does not translate well
> to GRASS/GDAL. Sorry for not being able to help.
> Maybe someone else on this list has experience with
> this type of data structure?
> At least now we know that r.in.gdal starts counting
> bands with "1"!
> Ben
> On 13/02/14 11:14, manuel.martin wrote:
> > I had already tried this (with "2") ;-). No luck either. Reading your
> > email I tried with "0" (maybe would gdal detect only two bands over
> > three). It comes out that only "band=1" works....
> > GRASS 7.0.svn (lambert93):~ > r.in.gdal --o
> input=/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/clc/clc06_250m
> > band=0 output=testclc
> > WARNING: Raster map <testclc> already exists and will be overwritten
> > WARNING: Datum <Not_specified_based_on_GRS_1980_ellipsoid> not recognised
> > by GRASS and no parameters found
> > Projection of input dataset and current location appear to match
> > ERROR 5:
> /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/clc/clc06_250m:
> > GDALDataset::GetRasterBand(0) - Illegal band #
> > ERROR: Selected band (0) does not exist
> > On 02/13/2014 10:59 AM, Benjamin Ducke wrote:
> >> Hmm, the manual page does not say so explicitely,
> >> but maybe band numbering starts with "0"?
> >> In that case your band 3 would have index number "2".
> >> Ben
> >> On 13/02/14 10:48, manuel.martin wrote:
> >>> Hi Ben,
> >>> Thanks for the reply. I tried with the band option but it looks like
> >>> gdal does not detect the multiple fields as multiple bands :
> >>> GRASS 7.0.svn (lambert93):~ > r.in.gdal --o \
> >>>> band=3 output=testclc
> >>> recognised
> >>> ERROR 5:
> >>> GDALDataset::GetRasterBand(3) - Illegal band #
> >>> ERROR: Selected band (3) does not exist
> >>> Cheers, Manuel
> >>> On 02/12/2014 08:25 PM, Benjamin Ducke wrote:
> >>>> Hi Manuel,
> >>>> GRASS does not support multi-band rasters, so you'll have
> >>>> to import each band as a separate raster map.
> >>>> r.in.gdal has the "band=" option to specify a band number
> >>>> to import.
> >>>> Best,
> >>>> Ben
> >>>> On 12/02/14 17:05, manuel.martin wrote:
> >>>>> Hi all,
> >>>>> I tried to import an ArcGIS binary raster (corine land cover for the
> >>>>> French territory) with three fields on each pixels (VALUE, COUNT and
> >>>>> CODE_06) using the *r.in.gdal* command. The import works just fine,
> >>>>> except that in the resulting raster, in GRASS, I only get one field,
> >>>>> which seems to be the VALUE field (and not the CODE_06 field, which
> >>>>> I am
> >>>>> interested in, and which is a categorical field, although coded with
> >>>>> integers).
> >>>>> Is there a way to produce a resulting raster with all the fields of
> >>>>> the
> >>>>> initial ArcGIS layer, or alternatively to choose one unique field?
> >>>>> Also,
> >>>>> is there a limitation on categorical fields. For instance, what if
> >>>>> instead of integer corine land cover codes I have literal labels,
> i.e.
> >>>>> levels of my categorical field coded with strings?
> >>>>> Cheers, Manuel
> >>>>> ----------------0----0------
> >>>>> INRA - InfoSol
> >>>>> Centre de recherche d'Orléans
> >>>>> 2163 Avenue de la Pomme de Pin
> >>>>> CS 40001 ARDON
> >>>>> 45075 ORLEANS Cedex 2
> >>>>> tel : (33) (0)2 38 41 48 21
> >>>>> fax : (33) (0)2 38 41 78 69
> >>>>> http://www.gissol.fr
> >>>>> ----0----0------------------
> >>>>> _______________________________________________
> >>>>> grass-user mailing list
> >>>>> grass-user at lists.osgeo.org
> >>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Dr. Benjamin Ducke, M.A.
> {*} Geospatial Consultant
> {*} GIS Developer
Nuno César de Sá
+351 91 961 90 37
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140213/44865ef2/attachment.html>
