[GRASS-user] r.in.gdal for importing categorical ArcGIS binary rasters
manuel.martin manuel.martin at orleans.inra.fr
Thu Feb 13 04:32:55 PST 2014
I think geoTiffs do not handle categorical variables (can anyone
confirm?), neither the writeRAST6() function from spgrass6 (tested
yesterday), and that's why I looked for a full GRASS option (avoiding
using R to go from ArcGIS to GRASS). So it is true that I can import
categorical ArcGIS binary rasters into R, but then I'm stuck into R and
cannot move to GRASS...
Manuel
On 02/13/2014 11:58 AM, Nuno Sá wrote:
> Out of the box:
> Import it in R and save it as a Tiff - use GRASS to open this tiff.
> Maybe it works ;P
> On 13 February 2014 10:50, Benjamin Ducke <benducke at fastmail.fm
> <mailto:benducke at fastmail.fm>> wrote:
>     Ouch. I am beginning to suspect that the ESRI "field"
>     concept for raster layers does not translate well
>     to GRASS/GDAL. Sorry for not being able to help.
>     Maybe someone else on this list has experience with
>     this type of data structure?
>     At least now we know that r.in.gdal starts counting
>     bands with "1"!
>     Ben
>     On 13/02/14 11:14, manuel.martin wrote:
>     > I had already tried this (with "2") ;-). No luck either. Reading
>     your
>     > email I tried with "0" (maybe would gdal detect only two bands over
>     > three). It comes out that only "band=1" works....
>     > GRASS 7.0.svn (lambert93):~ > r.in.gdal --o
>     input=/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/clc/clc06_250m
>     > band=0 output=testclc
>     > WARNING: Raster map <testclc> already exists and will be overwritten
>     > WARNING: Datum <Not_specified_based_on_GRS_1980_ellipsoid> not
>     recognised
>     >          by GRASS and no parameters found
>     > Projection of input dataset and current location appear to match
>     > ERROR 5:
>     /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/clc/clc06_250m:
>     > GDALDataset::GetRasterBand(0) - Illegal band #
>     > ERROR: Selected band (0) does not exist
>     > On 02/13/2014 10:59 AM, Benjamin Ducke wrote:
>     >> Hmm, the manual page does not say so explicitely,
>     >> but maybe band numbering starts with "0"?
>     >> In that case your band 3 would have index number "2".
>     >> Ben
>     >> On 13/02/14 10:48, manuel.martin wrote:
>     >>> Hi Ben,
>     >>> Thanks for the reply. I tried with the band option but it
>     looks like
>     >>> gdal does not detect the multiple fields as multiple bands :
>     >>> GRASS 7.0.svn (lambert93):~ > r.in.gdal --o \
>     >>>> band=3 output=testclc
>     overwritten
>     >>> recognised
>     >>> ERROR 5:
>     >>> GDALDataset::GetRasterBand(3) - Illegal band #
>     >>> ERROR: Selected band (3) does not exist
>     >>> Cheers, Manuel
>     >>> On 02/12/2014 08:25 PM, Benjamin Ducke wrote:
>     >>>> Hi Manuel,
>     >>>> GRASS does not support multi-band rasters, so you'll have
>     >>>> to import each band as a separate raster map.
>     >>>> r.in.gdal has the "band=" option to specify a band number
>     >>>> to import.
>     >>>> Best,
>     >>>> Ben
>     >>>> On 12/02/14 17:05, manuel.martin wrote:
>     >>>>> Hi all,
>     >>>>> I tried to import an ArcGIS binary raster (corine land cover
>     for the
>     >>>>> French territory) with three fields on each pixels (VALUE,
>     COUNT and
>     >>>>> CODE_06) using the *r.in.gdal* command. The import works
>     just fine,
>     >>>>> except that in the resulting raster, in GRASS, I only get
>     one field,
>     >>>>> which seems to be the VALUE field (and not the CODE_06
>     field, which
>     >>>>> I am
>     >>>>> interested in, and which is a categorical field, although
>     coded with
>     >>>>> integers).
>     >>>>> Is there a way to produce a resulting raster with all the
>     fields of
>     >>>>> the
>     >>>>> initial ArcGIS layer, or alternatively to choose one unique
>     field?
>     >>>>> Also,
>     >>>>> is there a limitation on categorical fields. For instance,
>     what if
>     >>>>> instead of integer corine land cover codes I have literal
>     labels, i.e.
>     >>>>> levels of my categorical field coded with strings?
>     >>>>> Cheers, Manuel
>     >>>>> ----------------0----0------
>     >>>>> INRA - InfoSol
>     >>>>> Centre de recherche d'Orléans
>     >>>>> 2163 Avenue de la Pomme de Pin
>     >>>>> CS 40001 ARDON
>     >>>>> 45075 ORLEANS Cedex 2
>     >>>>> tel : (33) (0)2 38 41 48 21
>     >>>>> fax : (33) (0)2 38 41 78 69
>     >>>>> http://www.gissol.fr
>     >>>>> ----0----0------------------
>     >>>>> _______________________________________________
>     >>>>> grass-user mailing list
>     >>>>> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>     >>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>     Dr. Benjamin Ducke, M.A.
>     {*} Geospatial Consultant
>     {*} GIS Developer
>     benducke at fastmail.fm <mailto:benducke at fastmail.fm>
> Nuno César de Sá
> +351 91 961 90 37
INRA - InfoSol
CS 40001 ARDON
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140213/aa6c6d7d/attachment-0001.html>
