[GRASS-user] r.in.gdal for importing categorical ArcGIS binary rasters
Moritz Lennert mlennert at club.worldonline.be
Thu Feb 13 07:31:03 PST 2014
On 13/02/14 13:32, manuel.martin wrote:
> I think geoTiffs do not handle categorical variables (can anyone
> confirm?), neither the writeRAST6() function from spgrass6 (tested
> yesterday), and that's why I looked for a full GRASS option (avoiding
> using R to go from ArcGIS to GRASS). So it is true that I can import
> categorical ArcGIS binary rasters into R, but then I'm stuck into R and
> cannot move to GRASS...
AFAIU, your "categorical" variables are just integers, or ? So no
problem to create a GeoTiff with them.
This said, what exactly is the format the data is in ? Is it really a
binary with several values per pixel, or do you have one value per pixel
and then a lookup table linking these values to clc categories ? ESRI's
binary ArcInfo Grid format has a specific file (vat.adf for Value
Attribute Table) which contains this lookup table, with a value and
count field.
In GRASS, the equivalent would be labels linked to category values. But
actually since the CLC categories are also integers, you could use those
as category values and put the text descriptions into the labels.
The CLC data contains a legend which links values to categories:
http://www.eea.europa.eu/data-and-maps/data/corine-land-cover-2006-raster#tab-additional-information
see  clc_legend.csv
Using that file and a bit of text handling magic you can easily create
an input file for r.reclass to create a map with clc categories as
values and the textual descriptions as labels.
Moritz
> Manuel
> On 02/13/2014 11:58 AM, Nuno Sá wrote:
>> Out of the box:
>> Import it in R and save it as a Tiff - use GRASS to open this tiff.
>> Maybe it works ;P
>> On 13 February 2014 10:50, Benjamin Ducke <benducke at fastmail.fm
>> <mailto:benducke at fastmail.fm>> wrote:
>>     Ouch. I am beginning to suspect that the ESRI "field"
>>     concept for raster layers does not translate well
>>     to GRASS/GDAL. Sorry for not being able to help.
>>     Maybe someone else on this list has experience with
>>     this type of data structure?
>>     At least now we know that r.in.gdal starts counting
>>     bands with "1"!
>>     Ben
>>     On 13/02/14 11:14, manuel.martin wrote:
>>     > I had already tried this (with "2") ;-). No luck either. Reading
>>     your
>>     > email I tried with "0" (maybe would gdal detect only two bands over
>>     > three). It comes out that only "band=1" works....
>>     > GRASS 7.0.svn (lambert93):~ > r.in.gdal --o
>>     input=/home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/clc/clc06_250m
>>     > band=0 output=testclc
>>     > WARNING: Raster map <testclc> already exists and will be overwritten
>>     > WARNING: Datum <Not_specified_based_on_GRS_1980_ellipsoid> not
>>     recognised
>>     >          by GRASS and no parameters found
>>     > Projection of input dataset and current location appear to match
>>     > ERROR 5:
>>     /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/clc/clc06_250m:
>>     > GDALDataset::GetRasterBand(0) - Illegal band #
>>     > ERROR: Selected band (0) does not exist
>>     > On 02/13/2014 10:59 AM, Benjamin Ducke wrote:
>>     >> Hmm, the manual page does not say so explicitely,
>>     >> but maybe band numbering starts with "0"?
>>     >> In that case your band 3 would have index number "2".
>>     >> Ben
>>     >> On 13/02/14 10:48, manuel.martin wrote:
>>     >>> Hi Ben,
>>     >>> Thanks for the reply. I tried with the band option but it
>>     looks like
>>     >>> gdal does not detect the multiple fields as multiple bands :
>>     >>> GRASS 7.0.svn (lambert93):~ > r.in.gdal --o \
>>     >>>> band=3 output=testclc
>>     overwritten
>>     >>> recognised
>>     >>> ERROR 5:
>>     >>> GDALDataset::GetRasterBand(3) - Illegal band #
>>     >>> ERROR: Selected band (3) does not exist
>>     >>> Cheers, Manuel
>>     >>> On 02/12/2014 08:25 PM, Benjamin Ducke wrote:
>>     >>>> Hi Manuel,
>>     >>>> GRASS does not support multi-band rasters, so you'll have
>>     >>>> to import each band as a separate raster map.
>>     >>>> r.in.gdal has the "band=" option to specify a band number
>>     >>>> to import.
>>     >>>> Best,
>>     >>>> Ben
>>     >>>> On 12/02/14 17:05, manuel.martin wrote:
>>     >>>>> Hi all,
>>     >>>>> I tried to import an ArcGIS binary raster (corine land cover
>>     for the
>>     >>>>> French territory) with three fields on each pixels (VALUE,
>>     COUNT and
>>     >>>>> CODE_06) using the *r.in.gdal* command. The import works
>>     just fine,
>>     >>>>> except that in the resulting raster, in GRASS, I only get
>>     one field,
>>     >>>>> which seems to be the VALUE field (and not the CODE_06
>>     field, which
>>     >>>>> I am
>>     >>>>> interested in, and which is a categorical field, although
>>     coded with
>>     >>>>> integers).
>>     >>>>> Is there a way to produce a resulting raster with all the
>>     fields of
>>     >>>>> the
>>     >>>>> initial ArcGIS layer, or alternatively to choose one unique
>>     field?
>>     >>>>> Also,
>>     >>>>> is there a limitation on categorical fields. For instance,
>>     what if
>>     >>>>> instead of integer corine land cover codes I have literal
>>     labels, i.e.
>>     >>>>> levels of my categorical field coded with strings?
>>     >>>>> Cheers, Manuel
>>     >>>>> ----------------0----0------
>>     >>>>> INRA - InfoSol
>>     >>>>> Centre de recherche d'Orléans
>>     >>>>> 2163 Avenue de la Pomme de Pin
>>     >>>>> CS 40001 ARDON
>>     >>>>> 45075 ORLEANS Cedex 2
>>     >>>>> tel : (33) (0)2 38 41 48 21
>>     >>>>> fax : (33) (0)2 38 41 78 69
>>     >>>>> http://www.gissol.fr
>>     >>>>> ----0----0------------------
>>     >>>>> _______________________________________________
>>     >>>>> grass-user mailing list
>>     >>>>> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>>     >>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>     Dr. Benjamin Ducke, M.A.
>>     {*} Geospatial Consultant
>>     {*} GIS Developer
>>     benducke at fastmail.fm <mailto:benducke at fastmail.fm>
>> Nuno César de Sá
>> +351 91 961 90 37
> INRA - InfoSol
> CS 40001 ARDON
