[GRASS-user] r.in.gdal for importing categorical ArcGIS binary rasters
Markus Metz markus.metz.giswork at gmail.com
Tue Feb 18 12:31:41 PST 2014
On Tue, Feb 18, 2014 at 2:09 PM, manuel.martin
<manuel.martin at orleans.inra.fr> wrote:
> On 02/18/2014 01:56 PM, Markus Metz wrote:
>> On Tue, Feb 18, 2014 at 1:14 PM, manuel.martin
>>> On 02/18/2014 12:47 PM, Markus Metz wrote:
>>>> On Tue, Feb 18, 2014 at 11:43 AM, manuel.martin
>>>>> Hi, I just compiled grass r59073 and gave a try.
>>>>> I could not get the attributes imported along with the raster, but
>>>>> maybe
>>>>> am
>>>>> I missing something from the new revision of r.in.gdal (although from
>>>>> the
>>>>> code it looks that the import of values from the attribute table should
>>>>> be
>>>>> automatic?).
>>>> Yes, r.in.gdal automatically imports whatever it finds as color tables
>>>> or attribute labels.
>>>>> Markus, I just sent you the ESRI layer I am trying to import, in case
>>>>> you
>>>>> would like to try as well.
>>>> GDAL does not see an attribute table in the data you sent to me, thus
>>>> GRASS can not import any attributes. If there is really an attribute
>>>> table, it is not recognized by GDAL.
>>> Then maybe this is a gdal problem : I'm saying this because through the
>>> command gdalinfo, it looks like gdal detects an attribute table (see
>>> below).
>>> Cheers
>>> GRASS 7.0.svn (lambert93):~/tmp > gdalinfo
>>> /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4
>>> Driver: AIG/Arc/Info Binary Grid
>>> Files:
>> This file is missing in the archive you sent:
>>> /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4.aux.xml
>> I am pretty sure that it contains the raster attribute table.
>> Markus M
> Sorry about that, I just sent the landforms/test_lf4.aux.xml to you, but
> unfortunately it does not seem to contain the raster attribute table...:
Right. Unfortunately I can not reproduce the gdalinfo output you sent
previously, and as long as gdal does not see an attribute table, GRASS
can not import the labels in the attribute table. I use gdal 1.10.1,
if that helps.
Markus M
> GRASS 7.0.svn (lambert93):~/tmp > more
> <PAMDataset>
> <SRS>PROJCS["RGF_1993_Lambert_93",GEOGCS["GCS_RGF_1993",DATUM["Reseau_Geodesique_Francais_1993",SPHEROID["GRS_1980",63
> 78137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic_2SP"],PARAM
> ETER["False_Easting",700000.0],PARAMETER["False_Northing",6600000.0],PARAMETER["Central_Meridian",3.0],PARAMETER["Standard_Pa
> rallel_1",44.0],PARAMETER["Standard_Parallel_2",49.0],PARAMETER["Latitude_Of_Origin",46.5],UNIT["Meter",1.0]]</SRS>
>   <PAMRasterBand band="1">
>     <Description>test_lf4</Description>
>     <Histograms>
>       <HistItem>
>         <HistMin>1</HistMin>
>         <HistMax>6</HistMax>
>         <BucketCount>256</BucketCount>
>         <IncludeOutOfRange>1</IncludeOutOfRange>
>         <Approximate>0</Approximate>
> <HistCounts>1313166|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|79933|0|0|0|0|0|0|0|0|0|0|0|0|0|
> 0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|110782|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0
> |0|0|0|0|0|0|0|0|0|0|42435|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|69408|0|0|0|0|0|0|0|0|0|0|0|0|0|0
> |0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|1341719</HistCounts>
>       </HistItem>
>     </Histograms>
>   </PAMRasterBand>
> </PAMDataset>
>>> /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/hdr.adf
>>> /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/dblbnd.adf
>>> /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/w001001.adf
>>> /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/w001001x.adf
>>> /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/sta.adf
>>> /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/vat.adf
>>> /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/log
>>> /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/prj.adf
>>> /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/metadata.xml
>>> Size is 2504, 2089
>>> Coordinate System is:
>>> PROJCS["unnamed",
>>>      GEOGCS["Unknown datum based upon the GRS 1980 ellipsoid",
>>>          DATUM["Not_specified_based_on_GRS_1980_ellipsoid",
>>>              SPHEROID["GRS 1980",6378137,298.257222101,
>>>                  AUTHORITY["EPSG","7019"]],
>>>              AUTHORITY["EPSG","6019"]],
>>>          PRIMEM["Greenwich",0,
>>>              AUTHORITY["EPSG","8901"]],
>>>          UNIT["degree",0.0174532925199433,
>>>              AUTHORITY["EPSG","9122"]],
>>>          AUTHORITY["EPSG","4019"]],
>>>      PARAMETER["standard_parallel_1",44],
>>>      PARAMETER["standard_parallel_2",49],
>>>      PARAMETER["latitude_of_origin",46.5],
>>>      PARAMETER["central_meridian",3],
>>>      PARAMETER["false_easting",700000],
>>>      PARAMETER["false_northing",6600000],
>>>      UNIT["METERS",1]]
>>> Origin = (198837.500000000000000,6808087.500000000000000)
>>> Pixel Size = (50.000000000000000,-50.000000000000000)
>>> Corner Coordinates:
>>> Upper Left  (  198837.500, 6808087.500) (  3d45' 3.55"W, 48d10'48.77"N)
>>> Lower Left  (  198837.500, 6703637.500) (  3d37'59.07"W, 47d14'36.54"N)
>>> Upper Right (  324037.500, 6808087.500) (  2d 4'11.49"W, 48d15'52.06"N)
>>> Lower Right (  324037.500, 6703637.500) (  1d58'52.06"W, 47d19'34.69"N)
>>> Center      (  261437.500, 6755862.500) (  2d51'32.26"W, 47d45'23.95"N)
>>> Band 1 Block=256x16 Type=Byte, ColorInterp=Undefined
>>>    Description = test_lf4
>>>    Min=1.000 Max=6.000
>>>    NoData Value=255
>>> <GDALRasterAttributeTable>
>>>    <FieldDefn index="0">
>>>      <Name>VALUE</Name>
>>>      <Type>0</Type>
>>>      <Usage>5</Usage>
>>>    </FieldDefn>
>>>    <FieldDefn index="1">
>>>      <Name>COUNT</Name>
>>>      <Type>0</Type>
>>>      <Usage>1</Usage>
>>>    </FieldDefn>
>>>    <FieldDefn index="2">
>>>      <Name>CLASS_NAME</Name>
>>>      <Type>2</Type>
>>>      <Usage>0</Usage>
>>>    </FieldDefn>
>>>    <Row index="0">
>>>      <F>1</F>
>>>      <F>1313166</F>
>>>      <F>Valleys</F>
>>>    </Row>
>>>    <Row index="1">
>>>      <F>2</F>
>>>      <F>79933</F>
>>>      <F>Lower Slopes</F>
>>>    </Row>
>>>    <Row index="2">
>>>      <F>3</F>
>>>      <F>110782</F>
>>>      <F>Gentle Slopes</F>
>>>    </Row>
>>>    <Row index="3">
>>>      <F>4</F>
>>>      <F>42435</F>
>>>      <F>Steep Slopes</F>
>>>    </Row>
>>>    <Row index="4">
>>>      <F>5</F>
>>>      <F>69408</F>
>>>      <F>Upper Slopes</F>
>>>    </Row>
>>>    <Row index="5">
>>>      <F>6</F>
>>>      <F>1341719</F>
>>>      <F>Ridges</F>
>>>    </Row>
>>> </GDALRasterAttributeTable>
>>>> Markus M
>>>>> Thank you in advance
>>>>> Manuel
>>>>> On 02/17/2014 02:48 PM, Markus Metz wrote:
>>>>>> On Fri, Feb 14, 2014 at 5:41 PM, manuel.martin
>>>>>>> On 02/14/2014 05:08 PM, Markus Metz wrote:
>>>>>>>> On Wed, Feb 12, 2014 at 5:05 PM, manuel.martin
>>>>>>>>> Hi all,
>>>>>>>>> I tried to import an ArcGIS binary raster (corine land cover for
>>>>>>>>> the
>>>>>>>>> French
>>>>>>>>> territory) with three fields on each pixels (VALUE, COUNT and
>>>>>>>>> CODE_06)
>>>>>>>>> using
>>>>>>>>> the r.in.gdal command. The import works just fine, except that in
>>>>>>>>> the
>>>>>>>>> resulting raster, in GRASS, I only get one field, which seems to be
>>>>>>>>> the
>>>>>>>>> VALUE field (and not the CODE_06 field, which I am interested in,
>>>>>>>>> and
>>>>>>>>> which
>>>>>>>>> is a categorical field, although coded with integers).
>>>>>>>> r.in.gdal will soon support import of category labels such as those
>>>>>>>> stored in the CODE_06 field. You can then inspect the labels with
>>>>>>>> r.category. GDAL supports reading and writing of raster attribute
>>>>>>>> tables, so far only the color rules stored in a raster attribute
>>>>>>>> table
>>>>>>>> are imported, but I plan to add import of labels to r.in.gdal. Note
>>>>>>>> that this applies only to GRASS 7.
>>>>>>>> Markus M
>>>>>>> Good to hear that ;-). I will wait for the next release of r.in.gdal
>>>>>> Done in r59073.
>>>>>> Markus M
>>>>>>> (meanwhile I did import clc vector layers with v.in.ogr and later
>>>>>>> managed
>>>>>>> the category labels with v.to.rast).
>>>>>>> All the best,           Manuel
>>>>>>>>> Is there a way to produce a resulting raster with all the fields of
>>>>>>>>> the
>>>>>>>>> initial ArcGIS layer, or alternatively to choose one unique field?
>>>>>>>>> Also,
>>>>>>>>> is
>>>>>>>>> there a limitation on categorical fields. For instance, what if
>>>>>>>>> instead
>>>>>>>>> of
>>>>>>>>> integer corine land cover codes I have literal labels, i.e. levels
>>>>>>>>> of
>>>>>>>>> my
>>>>>>>>> categorical field coded with strings?
>>>>>>>>> Cheers, Manuel
>>>>>>>>> ----------------0----0------
>>>>>>>>> INRA - InfoSol
>>>>>>>>> Centre de recherche d'Orléans
>>>>>>>>> 2163 Avenue de la Pomme de Pin
>>>>>>>>> CS 40001 ARDON
>>>>>>>>> 45075 ORLEANS Cedex 2
>>>>>>>>> tel : (33) (0)2 38 41 48 21
>>>>>>>>> fax : (33) (0)2 38 41 78 69
>>>>>>>>> http://www.gissol.fr
>>>>>>>>> ----0----0------------------
>>>>>>>>> _______________________________________________
>>>>>>>>> grass-user mailing list
>>>>>>>>> grass-user at lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>>>>>> INRA - InfoSol
>>>>>>> CS 40001 ARDON
>>>>> INRA - InfoSol
>>>>> CS 40001 ARDON
>>> INRA - InfoSol
>>> CS 40001 ARDON
> INRA - InfoSol
> CS 40001 ARDON
