[GRASS-user] r.in.gdal for importing categorical ArcGIS binary rasters
manuel.martin
manuel.martin at orleans.inra.fr
Thu Feb 20 00:32:27 PST 2014
On 02/18/2014 09:31 PM, Markus Metz wrote:
> On Tue, Feb 18, 2014 at 2:09 PM, manuel.martin
> <manuel.martin at orleans.inra.fr> wrote:
>> On 02/18/2014 01:56 PM, Markus Metz wrote:
>>> On Tue, Feb 18, 2014 at 1:14 PM, manuel.martin
>>>> On 02/18/2014 12:47 PM, Markus Metz wrote:
>>>>> On Tue, Feb 18, 2014 at 11:43 AM, manuel.martin
>>>>>> Hi, I just compiled grass r59073 and gave a try.
>>>>>> I could not get the attributes imported along with the raster, but
>>>>>> maybe
>>>>>> am
>>>>>> I missing something from the new revision of r.in.gdal (although from
>>>>>> the
>>>>>> code it looks that the import of values from the attribute table should
>>>>>> be
>>>>>> automatic?).
>>>>> Yes, r.in.gdal automatically imports whatever it finds as color tables
>>>>> or attribute labels.
>>>>>> Markus, I just sent you the ESRI layer I am trying to import, in case
>>>>>> you
>>>>>> would like to try as well.
>>>>> GDAL does not see an attribute table in the data you sent to me, thus
>>>>> GRASS can not import any attributes. If there is really an attribute
>>>>> table, it is not recognized by GDAL.
>>>> Then maybe this is a gdal problem : I'm saying this because through the
>>>> command gdalinfo, it looks like gdal detects an attribute table (see
>>>> below).
>>>> Cheers
>>>> GRASS 7.0.svn (lambert93):~/tmp > gdalinfo
>>>> /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4
>>>> Driver: AIG/Arc/Info Binary Grid
>>>> Files:
>>> This file is missing in the archive you sent:
>>>> /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4.aux.xml
>>> I am pretty sure that it contains the raster attribute table.
>>> Markus M
>> Sorry about that, I just sent the landforms/test_lf4.aux.xml to you, but
>> unfortunately it does not seem to contain the raster attribute table...:
> Right. Unfortunately I can not reproduce the gdalinfo output you sent
> previously, and as long as gdal does not see an attribute table, GRASS
> can not import the labels in the attribute table. I use gdal 1.10.1,
> if that helps.
> Markus M
I am running GDAL 1.10.0, maybe that explains the difference. I will let
you know when I will have 1.10.1 running if I still get the same
gdalinfo results.
Manuel
>> GRASS 7.0.svn (lambert93):~/tmp > more
>> <PAMDataset>
>> <SRS>PROJCS["RGF_1993_Lambert_93",GEOGCS["GCS_RGF_1993",DATUM["Reseau_Geodesique_Francais_1993",SPHEROID["GRS_1980",63
>> 78137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic_2SP"],PARAM
>> ETER["False_Easting",700000.0],PARAMETER["False_Northing",6600000.0],PARAMETER["Central_Meridian",3.0],PARAMETER["Standard_Pa
>> rallel_1",44.0],PARAMETER["Standard_Parallel_2",49.0],PARAMETER["Latitude_Of_Origin",46.5],UNIT["Meter",1.0]]</SRS>
>> <PAMRasterBand band="1">
>> <Description>test_lf4</Description>
>> <Histograms>
>> <HistItem>
>> <HistMin>1</HistMin>
>> <HistMax>6</HistMax>
>> <BucketCount>256</BucketCount>
>> <IncludeOutOfRange>1</IncludeOutOfRange>
>> <Approximate>0</Approximate>
>> <HistCounts>1313166|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|79933|0|0|0|0|0|0|0|0|0|0|0|0|0|
>> 0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|110782|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0
>> |0|0|0|0|0|0|0|0|0|0|42435|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|69408|0|0|0|0|0|0|0|0|0|0|0|0|0|0
>> |0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|1341719</HistCounts>
>> </HistItem>
>> </Histograms>
>> </PAMRasterBand>
>> </PAMDataset>
>>>> /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/hdr.adf
>>>> /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/dblbnd.adf
>>>> /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/w001001.adf
>>>> /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/w001001x.adf
>>>> /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/sta.adf
>>>> /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/vat.adf
>>>> /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/log
>>>> /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/prj.adf
>>>> /home/manuel/Desktop/sftp/Projets/Projets/Zones-humides/base_sig/dsm_data/landforms/test_lf4/metadata.xml
>>>> Size is 2504, 2089
>>>> Coordinate System is:
>>>> PROJCS["unnamed",
>>>> GEOGCS["Unknown datum based upon the GRS 1980 ellipsoid",
>>>> DATUM["Not_specified_based_on_GRS_1980_ellipsoid",
>>>> SPHEROID["GRS 1980",6378137,298.257222101,
>>>> AUTHORITY["EPSG","7019"]],
>>>> AUTHORITY["EPSG","6019"]],
>>>> PRIMEM["Greenwich",0,
>>>> AUTHORITY["EPSG","8901"]],
>>>> UNIT["degree",0.0174532925199433,
>>>> AUTHORITY["EPSG","9122"]],
>>>> AUTHORITY["EPSG","4019"]],
>>>> PARAMETER["standard_parallel_1",44],
>>>> PARAMETER["standard_parallel_2",49],
>>>> PARAMETER["latitude_of_origin",46.5],
>>>> PARAMETER["central_meridian",3],
>>>> PARAMETER["false_easting",700000],
>>>> PARAMETER["false_northing",6600000],
>>>> UNIT["METERS",1]]
>>>> Origin = (198837.500000000000000,6808087.500000000000000)
>>>> Pixel Size = (50.000000000000000,-50.000000000000000)
>>>> Corner Coordinates:
>>>> Upper Left ( 198837.500, 6808087.500) ( 3d45' 3.55"W, 48d10'48.77"N)
>>>> Lower Left ( 198837.500, 6703637.500) ( 3d37'59.07"W, 47d14'36.54"N)
>>>> Upper Right ( 324037.500, 6808087.500) ( 2d 4'11.49"W, 48d15'52.06"N)
>>>> Lower Right ( 324037.500, 6703637.500) ( 1d58'52.06"W, 47d19'34.69"N)
>>>> Center ( 261437.500, 6755862.500) ( 2d51'32.26"W, 47d45'23.95"N)
>>>> Band 1 Block=256x16 Type=Byte, ColorInterp=Undefined
>>>> Description = test_lf4
>>>> Min=1.000 Max=6.000
>>>> NoData Value=255
>>>> <GDALRasterAttributeTable>
>>>> <FieldDefn index="0">
>>>> <Name>VALUE</Name>
>>>> <Type>0</Type>
>>>> <Usage>5</Usage>
>>>> </FieldDefn>
>>>> <FieldDefn index="1">
>>>> <Name>COUNT</Name>
>>>> <Type>0</Type>
>>>> <Usage>1</Usage>
>>>> </FieldDefn>
>>>> <FieldDefn index="2">
>>>> <Name>CLASS_NAME</Name>
>>>> <Type>2</Type>
>>>> <Usage>0</Usage>
>>>> </FieldDefn>
>>>> <Row index="0">
>>>> <F>1</F>
>>>> <F>1313166</F>
>>>> <F>Valleys</F>
>>>> </Row>
>>>> <Row index="1">
>>>> <F>2</F>
>>>> <F>79933</F>
>>>> <F>Lower Slopes</F>
>>>> </Row>
>>>> <Row index="2">
>>>> <F>3</F>
>>>> <F>110782</F>
>>>> <F>Gentle Slopes</F>
>>>> </Row>
>>>> <Row index="3">
>>>> <F>4</F>
>>>> <F>42435</F>
>>>> <F>Steep Slopes</F>
>>>> </Row>
>>>> <Row index="4">
>>>> <F>5</F>
>>>> <F>69408</F>
>>>> <F>Upper Slopes</F>
>>>> </Row>
>>>> <Row index="5">
>>>> <F>6</F>
>>>> <F>1341719</F>
>>>> <F>Ridges</F>
>>>> </Row>
>>>> </GDALRasterAttributeTable>
>>>>> Markus M
>>>>>> Thank you in advance
>>>>>> Manuel
>>>>>> On 02/17/2014 02:48 PM, Markus Metz wrote:
>>>>>>> On Fri, Feb 14, 2014 at 5:41 PM, manuel.martin
>>>>>>>> On 02/14/2014 05:08 PM, Markus Metz wrote:
>>>>>>>>> On Wed, Feb 12, 2014 at 5:05 PM, manuel.martin
>>>>>>>>>> Hi all,
>>>>>>>>>> I tried to import an ArcGIS binary raster (corine land cover for
>>>>>>>>>> the
>>>>>>>>>> French
>>>>>>>>>> territory) with three fields on each pixels (VALUE, COUNT and
>>>>>>>>>> CODE_06)
>>>>>>>>>> using
>>>>>>>>>> the r.in.gdal command. The import works just fine, except that in
>>>>>>>>>> the
>>>>>>>>>> resulting raster, in GRASS, I only get one field, which seems to be
>>>>>>>>>> the
>>>>>>>>>> VALUE field (and not the CODE_06 field, which I am interested in,
>>>>>>>>>> and
>>>>>>>>>> which
>>>>>>>>>> is a categorical field, although coded with integers).
>>>>>>>>> r.in.gdal will soon support import of category labels such as those
>>>>>>>>> stored in the CODE_06 field. You can then inspect the labels with
>>>>>>>>> r.category. GDAL supports reading and writing of raster attribute
>>>>>>>>> tables, so far only the color rules stored in a raster attribute
>>>>>>>>> table
>>>>>>>>> are imported, but I plan to add import of labels to r.in.gdal. Note
>>>>>>>>> that this applies only to GRASS 7.
>>>>>>>>> Markus M
>>>>>>>> Good to hear that ;-). I will wait for the next release of r.in.gdal
>>>>>>> Done in r59073.
>>>>>>> Markus M
>>>>>>>> (meanwhile I did import clc vector layers with v.in.ogr and later
>>>>>>>> managed
>>>>>>>> the category labels with v.to.rast).
>>>>>>>> All the best, Manuel
>>>>>>>>>> Is there a way to produce a resulting raster with all the fields of
>>>>>>>>>> the
>>>>>>>>>> initial ArcGIS layer, or alternatively to choose one unique field?
>>>>>>>>>> Also,
>>>>>>>>>> is
>>>>>>>>>> there a limitation on categorical fields. For instance, what if
>>>>>>>>>> instead
>>>>>>>>>> of
>>>>>>>>>> integer corine land cover codes I have literal labels, i.e. levels
>>>>>>>>>> of
>>>>>>>>>> my
>>>>>>>>>> categorical field coded with strings?
>>>>>>>>>> Cheers, Manuel
>>>>>>>>>> ----------------0----0------
>>>>>>>>>> INRA - InfoSol
>>>>>>>>>> Centre de recherche d'Orléans
>>>>>>>>>> 2163 Avenue de la Pomme de Pin
>>>>>>>>>> CS 40001 ARDON
>>>>>>>>>> 45075 ORLEANS Cedex 2
>>>>>>>>>> tel : (33) (0)2 38 41 48 21
>>>>>>>>>> fax : (33) (0)2 38 41 78 69
>>>>>>>>>> http://www.gissol.fr
>>>>>>>>>> ----0----0------------------
>>>>>>>>>> _______________________________________________
>>>>>>>>>> grass-user mailing list
>>>>>>>>>> grass-user at lists.osgeo.org
>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>>>>>>> INRA - InfoSol
>>>>>>>> CS 40001 ARDON
>>>>>> INRA - InfoSol
>>>>>> CS 40001 ARDON
>>>> INRA - InfoSol
>>>> CS 40001 ARDON
>> INRA - InfoSol
>> CS 40001 ARDON
INRA - InfoSol
CS 40001 ARDON
