[GRASS-user] v.in.lidar finds 0 points in GRASS 7
Markus Metz
markus.metz.giswork at gmail.com
Wed Feb 19 23:38:14 PST 2014
On Thu, Feb 20, 2014 at 2:24 AM, Michael Moore <stuporglue at gmail.com> wrote:
> Hello,
> I think I'm doing something wrong with importing lidar data in GRASS 7.
> My data is a laz file from the state of Minnesota.
> The complicating factor is that the EPSG code is set incorrectly --
> EPSG:32715 / UTM 15 S instead of EPSG:26715/UTM 15 N. My region is set to
> the correct 26715.
> I am using the GUI, but the command that it generates is
> v.in.lidar -p -o --overwrite input=/data/3542-27-22.laz output=test
> The output is:
> Over-riding projection check
> Importing 0 points...
> Building topology for vector map <test at stuporglue>...
> Registering primitives...
> 0 primitives registered
> 0 vertices registered
> Building areas...
> 0 areas built
> 0 isles built
> Attaching islands...
> Attaching centroids...
> Number of nodes: 0
> Number of primitives: 0
> Number of points: 0
> Number of lines: 0
> Number of boundaries: 0
> Number of centroids: 0
> Number of areas: 0
> Number of isles: 0
> 0 points imported
> lasinfo reports 12588100 points.
v.in.lidar imports only valid points. How many valid points does lasinfo report?
Markus M
> I'd be happy to get this imported either through the command line or the
> GUI, but my goal is to understand enough about GRASS to script the creation
> of a state-wide DSM from LiDAR data.
> Thanks,
> Michael Moore
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
