[GRASS-user] broken d.mon
Vaclav Petras wenzeslaus at gmail.com
Fri Feb 21 12:52:43 PST 2014
Hi Dave,
let's keep the conversation on list. I hope you don't mind.
On Fri, Feb 21, 2014 at 2:57 PM, Dave Roberts <
dvrbts at ecology.msu.montana.edu> wrote:
> Hi Vaclav,
>     Thanks for your help.  I'm running Scientific Linux 6 (EL6-based).
>  when I enter d.mon x0 it says there is no such monitor.
Isn't there some problem with compilation? I'm not sure if this is even
possible but maybe compilation can be set in the way that no monitors are
included.
> The command
> d.mon -l
generates
> no known monitors
> Hm, now I understand what you are saying, -l behavior differs for 6 and 7.
http://grass.osgeo.org/grass64/manuals/d.mon.html
http://grass.osgeo.org/grass70/manuals/d.mon.html
> So, no x0-9, no png, no nothing.
> Thanks, Dave
> On 02/21/2014 10:56 AM, Vaclav Petras wrote:
>> What happens if you write
>> d.mon x0
>> Note that X monitors does not work on MS Windows.
>> On Fri, Feb 21, 2014 at 12:17 PM, Dave Roberts
>> <dvrbts at ecology.msu.montana.edu <mailto:dvrbts at ecology.msu.montana.edu>>
>> wrote:
>>     Hi Martin,
>>         Thanks.  I do understand that.  But now I have no X monitors
>>     (nor png or anything else for that matter).
>>     Dave
>>     On 02/21/2014 09:18 AM, Martin Landa wrote:
>>         Hi,
>>         2014-02-21 17:10 GMT+01:00 Dave
>>         Roberts<dvrbts at ecology.msu.__montana.edu
>>         <mailto:dvrbts at ecology.msu.montana.edu>>:
>>             d.mon wx0
>>             in GRASS64.  It not only did not display, now no monitors
>>             exist, i.e.
>>         this is not possible in G6. Here d.mon works with X-based
>> monitors,
>>         ie. d.mon x0.
>>         Martin
>>     ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~__~~~~~~~~~~~~~~~~~~~~~~~~~~~~
>> ~~__~~~~~~~~~~~~
>>     David W. Roberts                                     office
>>     406-994-4548 <tel:406-994-4548>
>>     Professor and Head                                      FAX
>>     406-994-3190 <tel:406-994-3190>
>>     Department of Ecology                         email
>>     droberts at montana.edu <mailto:droberts at montana.edu>
>>     Montana State University
>>     Bozeman, MT 59717-3460
>>     _________________________________________________
>>     grass-user mailing list
>>     grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>>     http://lists.osgeo.org/__mailman/listinfo/grass-user
>>     <http://lists.osgeo.org/mailman/listinfo/grass-user>
> David W. Roberts                                     office 406-994-4548
> Professor and Head                                      FAX 406-994-3190
> Department of Ecology                         email droberts at montana.edu
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140221/8d9ec12e/attachment.html>
