[GRASS-user] broken d.mon
Dave Roberts dvrbts at ecology.msu.montana.edu
Fri Feb 21 13:06:54 PST 2014
Hi Vaclav,
    Happy to stay on list.  I'm grateful for all the help I've received
here.
    So, the problem is not with compilation.  GRASS64 was working well
on my system (except for v.dissolve and lib gmath, see other list
issues).  Oddly, when I mistakenly entered d.mon wx0 it not only didn't
work (which should be expected), it disabled all the other monitor
options (seemingly permanently).  When I changed to another location the
problem persisted which really surprised me.
    Fortunately I have other machines to work on, but this is my primary
machine for a large research project that emphasized GRASS.  I'm in the
process of moving to GRASS7, but I couldn't get it to compile on this
machine (Markus N is helping me with that), so I stayed with GRASS64.
Thanks, Dave
On 02/21/2014 01:52 PM, Vaclav Petras wrote:
> Hi Dave,
> let's keep the conversation on list. I hope you don't mind.
> On Fri, Feb 21, 2014 at 2:57 PM, Dave Roberts
> <dvrbts at ecology.msu.montana.edu <mailto:dvrbts at ecology.msu.montana.edu>>
> wrote:
>     Hi Vaclav,
>          Thanks for your help.  I'm running Scientific Linux 6
>     (EL6-based).  when I enter d.mon x0 it says there is no such monitor.
> Isn't there some problem with compilation? I'm not sure if this is even
> possible but maybe compilation can be set in the way that no monitors
> are included.
>     The command
>     d.mon -l
>     generates
>     no known monitors
> Hm, now I understand what you are saying, -l behavior differs for 6 and 7.
> http://grass.osgeo.org/grass64/manuals/d.mon.html
> http://grass.osgeo.org/grass70/manuals/d.mon.html
>     So, no x0-9, no png, no nothing.
>     Thanks, Dave
>     On 02/21/2014 10:56 AM, Vaclav Petras wrote:
>         What happens if you write
>         d.mon x0
>         Note that X monitors does not work on MS Windows.
>         On Fri, Feb 21, 2014 at 12:17 PM, Dave Roberts
>         <dvrbts at ecology.msu.montana.__edu
>         <mailto:dvrbts at ecology.msu.__montana.edu
>         <mailto:dvrbts at ecology.msu.montana.edu>>>
>         wrote:
>              Hi Martin,
>                  Thanks.  I do understand that.  But now I have no X
>         monitors
>              (nor png or anything else for that matter).
>              Dave
>              On 02/21/2014 09:18 AM, Martin Landa wrote:
>                  Hi,
>                  2014-02-21 17:10 GMT+01:00 Dave
>                  Roberts<dvrbts at ecology.msu.__m__ontana.edu
>         <http://montana.edu>
>         <mailto:dvrbts at ecology.msu.montana.edu>>>:
>                      d.mon wx0
>                      in GRASS64.  It not only did not display, now no
>         monitors
>                      exist, i.e.
>                  this is not possible in G6. Here d.mon works with
>         X-based monitors,
>                  ie. d.mon x0.
>                  Martin
>         ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~____~~~~~~~~~~~~~~~~~~~~~~~~~~~~__~~__~~~~~~~~~~~~
>              David W. Roberts                                     office
>         406-994-4548 <tel:406-994-4548> <tel:406-994-4548
>         <tel:406-994-4548>>
>              Professor and Head                                      FAX
>         406-994-3190 <tel:406-994-3190> <tel:406-994-3190
>         <tel:406-994-3190>>
>              Department of Ecology                         email
>         droberts at montana.edu <mailto:droberts at montana.edu>
>         <mailto:droberts at montana.edu <mailto:droberts at montana.edu>>
>              Montana State University
>              Bozeman, MT 59717-3460
>              ___________________________________________________
>              grass-user mailing list
>         grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>         <mailto:grass-user at lists.__osgeo.org
>         <mailto:grass-user at lists.osgeo.org>>
>         http://lists.osgeo.org/____mailman/listinfo/grass-user
>         <http://lists.osgeo.org/__mailman/listinfo/grass-user>
>         <http://lists.osgeo.org/mailman/listinfo/grass-user>>
>     ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~__~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~__~~~~~~~~~~~~
David W. Roberts                                     office 406-994-4548
Professor and Head                                      FAX 406-994-3190
Department of Ecology                         email droberts at montana.edu
