[GRASS-user] grass-python editing using Wing-IDE
Vaclav Petras
wenzeslaus at gmail.com
Fri Jan 17 11:50:31 PST 2014
On Fri, Jan 17, 2014 at 2:23 PM, Milton Ribeiro <
miltinho.astronauta at gmail.com> wrote:
> Dear all,
> I would like to know if is there anyone using
> WingIDE python editor to write python grass scripting.
> I am using WingIDE under windows, but grass.scripting lib methods not
> autocomplete, and the help of grass.scripting not appears on WingIDE as for
> other libs of python.
> I'm not using WingIDE nor Windows, so I hope somebody else will reply, too.
However, (for several reasons) grass.script is not installed to the system
(to the python installation), so you need to tell your IDE where to look
for the grass.scripting. One possibility is to set PYTHONPATH environmental
variable (which will then appear in sys.path in python) for the IDE:
http://www.wingware.com/doc/intro/tutorial-python-path
Maybe there is some settings even directly in the editor. The path should
be set to the directory where grass.script, i.e. something like:
C:\path\to\grass\etc\python\
The way which works the best for me, on Ubuntu with Spyder Python IDE, is
starting the editor from within the GRASS session (GRASS command line).
This ensures that the environment is set right and you not only have the
autocomplete and documentation but also that you can run your python GRASS
scripts in the IDE. In theory, this should work the same on MS Windows.
Vaclav
best wishes
> Miltinho - mcr at rc.unesp.br
> Laboratório de Ecologia Espacial e Conservação - LEEC
> Depto de Ecologia - UNESP - Rio Claro
> Av. 24A, 1515- Bela Vista
> 13506-900 Rio Claro, SP, Brasil
> Fone: +55 19 3526-9647 (office) 19 3526-9680 (lab)
> Cel: 19 9853-3220 / 19 9853-5430
> Depto Ecologia http://ib.rc.unesp.br/#!/departamentos/ecologia/
> PG ECO & BIODIV
> http://ib.rc.unesp.br/#!/departamentos/ecologia/pos-graduacao-em-ecologia-e-biodiversidade/
> CV
> http://buscatextual.cnpq.br/buscatextual/visualizacv.do?id=K4792988H6&mostrarNroCitacoesISI=true&mostrarNroCitacoesScopus=true
> Google citations http://scholar.google.com/citations?user=OWX_2eAAAAAJ
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140117/fe2c01ee/attachment.html>
