[GRASS-user] grass-python editing using Wing-IDE
Milton Ribeiro miltinho.astronauta at gmail.com
Sat Jan 18 15:03:05 PST 2014
Dear Anna and Vaclav,
thanks a lot for your kind reply.
I tried to find grass.script to define de proper address where it is, or to
copy this to my python/lib directory but I could'nt find.
I am using window 8.
Any hint are welcome.
best
milton
2014/1/17 Vaclav Petras <wenzeslaus at gmail.com>
> On Fri, Jan 17, 2014 at 2:23 PM, Milton Ribeiro <
> miltinho.astronauta at gmail.com> wrote:
>> Dear all,
>> I would like to know if is there anyone using
>> WingIDE python editor to write python grass scripting.
>> I am using WingIDE under windows, but grass.scripting lib methods not
>> autocomplete, and the help of grass.scripting not appears on WingIDE as for
>> other libs of python.
>> I'm not using WingIDE nor Windows, so I hope somebody else will reply,
> too.
> However, (for several reasons) grass.script is not installed to the system
> (to the python installation), so you need to tell your IDE where to look
> for the grass.scripting. One possibility is to set PYTHONPATH environmental
> variable (which will then appear in sys.path in python) for the IDE:
> http://www.wingware.com/doc/intro/tutorial-python-path
> Maybe there is some settings even directly in the editor. The path should
> be set to the directory where grass.script, i.e. something like:
> C:\path\to\grass\etc\python\
> The way which works the best for me, on Ubuntu with Spyder Python IDE, is
> starting the editor from within the GRASS session (GRASS command line).
> This ensures that the environment is set right and you not only have the
> autocomplete and documentation but also that you can run your python GRASS
> scripts in the IDE. In theory, this should work the same on MS Windows.
> Vaclav
>  best wishes
>> Miltinho - mcr at rc.unesp.br
>> Laboratório de Ecologia Espacial e Conservação - LEEC
>> Depto de Ecologia - UNESP - Rio Claro
>> Av. 24A, 1515- Bela Vista
>> 13506-900 Rio Claro, SP, Brasil
>> Fone: +55 19 3526-9647 (office)  19 3526-9680 (lab)
>> Cel: 19 9853-3220 / 19 9853-5430
>> Depto Ecologia http://ib.rc.unesp.br/#!/departamentos/ecologia/
>> PG ECO & BIODIV
>> http://ib.rc.unesp.br/#!/departamentos/ecologia/pos-graduacao-em-ecologia-e-biodiversidade/
>> CV
>> http://buscatextual.cnpq.br/buscatextual/visualizacv.do?id=K4792988H6&mostrarNroCitacoesISI=true&mostrarNroCitacoesScopus=true
>> Google citations http://scholar.google.com/citations?user=OWX_2eAAAAAJ
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
PG ECO & BIODIV
CV
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140118/f28e13d8/attachment.html>
