[GRASS-user] grass-python editing using Wing-IDE
Milton Ribeiro
miltinho.astronauta at gmail.com
Sat Jan 18 15:47:50 PST 2014
Hi there
Just to keep the info, I found it, and now everything is working fine with
autocomplete under Wingware.
I copied the folder "C:\Program Files (x86)\GRASS GIS
6.4.3RC2\etc\python\grass" to
"C:\Python27\Lib\site-packages"
Thanks again
milton
2014/1/18 Milton Ribeiro <miltinho.astronauta at gmail.com>
> Dear Anna and Vaclav,
> thanks a lot for your kind reply.
> I tried to find grass.script to define de proper address where it is, or
> to copy this to my python/lib directory but I could'nt find.
> I am using window 8.
> Any hint are welcome.
> best
> milton
> 2014/1/17 Vaclav Petras <wenzeslaus at gmail.com>
>> On Fri, Jan 17, 2014 at 2:23 PM, Milton Ribeiro <
>> miltinho.astronauta at gmail.com> wrote:
>>> Dear all,
>>> I would like to know if is there anyone using
>>> WingIDE python editor to write python grass scripting.
>>> I am using WingIDE under windows, but grass.scripting lib methods not
>>> autocomplete, and the help of grass.scripting not appears on WingIDE as for
>>> other libs of python.
>>> I'm not using WingIDE nor Windows, so I hope somebody else will reply,
>> too.
>> However, (for several reasons) grass.script is not installed to the
>> system (to the python installation), so you need to tell your IDE where to
>> look for the grass.scripting. One possibility is to set PYTHONPATH
>> environmental variable (which will then appear in sys.path in python) for
>> the IDE:
>> http://www.wingware.com/doc/intro/tutorial-python-path
>> Maybe there is some settings even directly in the editor. The path should
>> be set to the directory where grass.script, i.e. something like:
>> C:\path\to\grass\etc\python\
>> The way which works the best for me, on Ubuntu with Spyder Python IDE, is
>> starting the editor from within the GRASS session (GRASS command line).
>> This ensures that the environment is set right and you not only have the
>> autocomplete and documentation but also that you can run your python GRASS
>> scripts in the IDE. In theory, this should work the same on MS Windows.
>> Vaclav
>> best wishes
>>> Miltinho - mcr at rc.unesp.br
>>> Laboratório de Ecologia Espacial e Conservação - LEEC
>>> Depto de Ecologia - UNESP - Rio Claro
>>> Av. 24A, 1515- Bela Vista
>>> 13506-900 Rio Claro, SP, Brasil
>>> Fone: +55 19 3526-9647 (office) 19 3526-9680 (lab)
>>> Cel: 19 9853-3220 / 19 9853-5430
>>> Depto Ecologia http://ib.rc.unesp.br/#!/departamentos/ecologia/
>>> PG ECO & BIODIV
>>> http://ib.rc.unesp.br/#!/departamentos/ecologia/pos-graduacao-em-ecologia-e-biodiversidade/
>>> CV
>>> http://buscatextual.cnpq.br/buscatextual/visualizacv.do?id=K4792988H6&mostrarNroCitacoesISI=true&mostrarNroCitacoesScopus=true
>>> Google citations http://scholar.google.com/citations?user=OWX_2eAAAAAJ
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
> PG ECO & BIODIV
> CV
PG ECO & BIODIV
CV
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140118/a9047e14/attachment.html>
