[GRASS-user] importing bil file errors
Markus Neteler
neteler at osgeo.org
Tue Jan 21 06:09:21 PST 2014
On Tue, Jan 21, 2014 at 12:11 AM, Tyler Smith <tyler at plantarum.ca> wrote:
> Markus Neteler <neteler at osgeo.org> wrote:
>>the data set lacks the projection metadata, hence GRASS cannot guess
>>that:
>>So, GRASS 7 import:
>>grass70 -c EPSG:4326 ~/grassdata/hwsd
> How did you find the projection? Not having any GIS training, projections are the most confusing part of GRASS to me.
I searched online and found some references about the data set.
It is not GRASS' fault that this information is lacking in the dataset :-)
I have now made the EPSG code it a link in the wiki.
>># ops, too big for our CAIRO driver :p
>>ERROR: Cairo_begin_raster(): Failed to create surface (invalid value
>> (typically too big) for the size of the input (surface, pattern,
>> etc.))
> Ah, I see now. The error message is a little cryptic.
Moreover, it should ideally not happen. It will hopefully be solved.
>>For convenience added to the Wiki, too:
>>http://grasswiki.osgeo.org/wiki/Global_datasets#Harmonized_World_Soil_Database_.28HWSD_Database.29
> Wow! I didn't know thIs kind of info is on the wiki. That is *very* helpful indeed.
>>Hope this helps,
> Very much, thank you!
you are welcome.
Markus
> Tyler
