[GRASS-user] how to draw line with arrow mark to line top (tip)
SGW00412 at nifty.com
Fri Jan 24 04:54:27 PST 2014
Dear Vincent
Thank you for useful information and advices !
I didnot know it.
I wiil try it!
Best
Yasuo SHIMADA (japan weather associaton)
Vincent Bain <bain at toraval.fr>さん:
> Hello Yasuo,
> If you just need to display line directions with an arrow head on
> end-node, you can use the "display=dir" option available for d.vect.
> If you need to display a custom symbol, you cannot use "icon=" option,
> which is dedicated to point and centroid features (not lines).
> Envethough the following case describes a method to compose a hardcopy
> map, this wiki entry can help you :
> http://grasswiki.osgeo.org/wiki/Tips_and_Tricks#Compensate_the_lack_of_line_ends_symbology_in_ps.map
> The idea is to create a point vector where points are assigned a
> rotation angle value corresponding to the line last (or first) segment
> orientation. Then you just have to call d.vect whith "icon=" and
> "rot_column=" options.
> Good luck!
> Vincent
> Le vendredi 24 janvier 2014 à 14:12 +0900, sgw00412 at nifty.com a écrit :
> > Hollow grass users
> > I'm from Japan, and biggner.
> > I do not find how to draw line with arrow mark to line top (tip).
> > for exsample...
> > normally line;
> > line with arrow mark to line top (tip);
> > or
> > I read online manual and tried to command 'd.vect layer_name icon=basic/
arrow1
> > ', however nothing happend....
> > Does anyone to know it?
> > Best
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
