[GRASS-user] g.extension -
Vaclav Petras
wenzeslaus at gmail.com
Fri Jan 31 13:07:51 PST 2014
On Fri, Jan 31, 2014 at 3:56 PM, Craig Aumann <craigaumann at gmail.com> wrote:
> Ok - so to work around the problem I compiled GRASS 70 with the following
> flags following the instructions at
> http://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu#GRASS_GIS
> Not seeing any compilation errors.
> CFLAGS="-O2 -Wall" LDFLAGS="-s" ./configure \
> --enable-largefile=yes \
> --enable-64bit \
> --with-libs=/usr/lib \
> --with-nls \
> --with-cxx \
> --with-proj-share=/usr/share/proj \
> --with-geos=/usr/bin/geos-config \
> --with-readline \
> --with-python=yes \
> --with-wxwidgets \
> --with-cairo \
> --with-opengl-libs=/usr/include/GL \
> --with-motif \
> --with-tcltk-includes="/usr/include/tcl8.5" \
> --with-ffmpeg=yes --with-ffmpeg-includes="/usr/include/libavcodec
> /usr/include/libavformat /usr/include/libswscale /usr/include/libavutil" \
> --with-freetype=yes --with-freetype-includes="/usr/include/freetype2/" \
> --with-postgres=no \
> --with-postgresql=no \
> --with-sqlite=yes \
> --with-mysql=no \
> --with-odbc=no
> When I start grass 70 I get:
> Hit RETURN to continue
> Starting GRASS GIS...
> access: No such file or directory
> ERROR: LOCATION </home/caumann/<UNKNOWN>> not available
> Traceback (most recent call last):
> File "/usr/local/grass-7.0.svn/etc/gui/wxpython/gis_set.py", line 48, in
> <module>
> from gui_core.dialogs import TextEntryDialog
> File "/usr/local/grass-7.0.svn/etc/gui/wxpython/gui_core/dialogs.py",
> line 49, in <module>
> from gui_core.gselect import LocationSelect, MapsetSelect, Select, \
> File "/usr/local/grass-7.0.svn/etc/gui/wxpython/gui_core/gselect.py",
> line 59, in <module>
> import grass.temporal as tgis
> File "/usr/local/grass-7.0.svn/etc/python/grass/temporal/__init__.py",
> line 29, in <module>
> from temporal_vector_algebra import *
> File
> "/usr/local/grass-7.0.svn/etc/python/grass/temporal/temporal_vector_algebra.py",
> line 436, in <module>
> m_overlay = pygrass.Module('v.overlay', quiet=True, run_=False)
> File
> "/usr/local/grass-7.0.svn/etc/python/grass/pygrass/modules/interface/module.py",
> line 252, in __init__
> tree = fromstring(self.xml)
> File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1302, in XML
> return parser.close()
> File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1655, in close
> self._raiseerror(v)
> File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1507, in
> _raiseerror
> raise err
> xml.etree.ElementTree.ParseError: no element found: line 1, column 0
> Error in GUI startup. If necessary, please report this error to the GRASS
> developers.
> Switching to text mode now.
> Hit RETURN to continue...
> ^CTraceback (most recent call last):
> File "/usr/local/bin/grass70", line 1324, in <module>
> set_data()
> File "/usr/local/bin/grass70", line 679, in set_data
> gui_startup()
> File "/usr/local/bin/grass70", line 700, in gui_startup
> sys.stdin.readline()
> KeyboardInterrupt
> What did I forget to include???
> You did everything right and you discovered another bug. I unfortunately
cannot reproduce it (Ubuntu 12.04).
Try please GRASS revision 58806:
svn up -r58806
make distclean
./configure...
make
./bin.../grass70
and if it will work (and you will have still strength to continue) please
try also revision 58807.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140131/c0487f73/attachment.html>
