[GRASS-user] g.extension -
caumann
craigaumann at gmail.com
Fri Jan 31 13:46:15 PST 2014
The good news is that r58806 works!
Bad news is that r58807 is giving the same errors as what I had before:
ERROR: LOCATION </home/caumann/Desktop/<UNKNOWN>> not available
File "/usr/local/grass-7.0.svn/etc/gui/wxpython/gis_set.py", line 48, in
<module>
from gui_core.dialogs import TextEntryDialog
File "/usr/local/grass-7.0.svn/etc/gui/wxpython/gui_core/dialogs.py",
line 49, in <module>
from gui_core.gselect import LocationSelect, MapsetSelect, Select, \
File "/usr/local/grass-7.0.svn/etc/gui/wxpython/gui_core/gselect.py",
line 59, in <module>
import grass.temporal as tgis
File "/usr/local/grass-7.0.svn/etc/python/grass/temporal/__init__.py",
line 29, in <module>
from temporal_vector_algebra import *
File
"/usr/local/grass-7.0.svn/etc/python/grass/temporal/temporal_vector_algebra.py",
line 436, in <module>
Anyways - I'm a tad happier now and thanks for everyone's help!
On Fri, Jan 31, 2014 at 2:08 PM, wenzeslaus [via OSGeo.org] <
ml-node+s1560n5101289h80 at n6.nabble.com> wrote:
> On Fri, Jan 31, 2014 at 3:56 PM, Craig Aumann <[hidden email]<http://user/SendEmail.jtp?type=node&node=5101289&i=0>
> > wrote:
>> Ok - so to work around the problem I compiled GRASS 70 with the following
>> flags following the instructions at
>> http://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu#GRASS_GIS
>> Not seeing any compilation errors.
>> CFLAGS="-O2 -Wall" LDFLAGS="-s" ./configure \
>> --enable-largefile=yes \
>> --enable-64bit \
>> --with-libs=/usr/lib \
>> --with-nls \
>> --with-cxx \
>> --with-proj-share=/usr/share/proj \
>> --with-geos=/usr/bin/geos-config \
>> --with-readline \
>> --with-python=yes \
>> --with-wxwidgets \
>> --with-cairo \
>> --with-opengl-libs=/usr/include/GL \
>> --with-motif \
>> --with-tcltk-includes="/usr/include/tcl8.5" \
>> --with-ffmpeg=yes --with-ffmpeg-includes="/usr/include/libavcodec
>> /usr/include/libavformat /usr/include/libswscale /usr/include/libavutil" \
>> --with-freetype=yes --with-freetype-includes="/usr/include/freetype2/" \
>> --with-postgres=no \
>> --with-postgresql=no \
>> --with-sqlite=yes \
>> --with-mysql=no \
>> --with-odbc=no
>> When I start grass 70 I get:
>> Hit RETURN to continue
>> Starting GRASS GIS...
>> access: No such file or directory
>> ERROR: LOCATION </home/caumann/<UNKNOWN>> not available
>> in <module>
>> File
>> m_overlay = pygrass.Module('v.overlay', quiet=True, run_=False)
>> File
>> "/usr/local/grass-7.0.svn/etc/python/grass/pygrass/modules/interface/module.py",
>> line 252, in __init__
>> tree = fromstring(self.xml)
>> File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1302, in XML
>> return parser.close()
>> File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1655, in close
>> self._raiseerror(v)
>> File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1507, in
>> _raiseerror
>> raise err
>> xml.etree.ElementTree.ParseError: no element found: line 1, column 0
>> Error in GUI startup. If necessary, please report this error to the GRASS
>> developers.
>> Switching to text mode now.
>> Hit RETURN to continue...
>> ^CTraceback (most recent call last):
>> File "/usr/local/bin/grass70", line 1324, in <module>
>> set_data()
>> File "/usr/local/bin/grass70", line 679, in set_data
>> gui_startup()
>> File "/usr/local/bin/grass70", line 700, in gui_startup
>> sys.stdin.readline()
>> KeyboardInterrupt
>> What did I forget to include???
>> You did everything right and you discovered another bug. I unfortunately
> cannot reproduce it (Ubuntu 12.04).
> Try please GRASS revision 58806:
> svn up -r58806
> make distclean
> ./configure...
> make
> ./bin.../grass70
> and if it will work (and you will have still strength to continue) please
> try also revision 58807.
>> grass-user mailing list
>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5101289&i=1>
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5101289&i=2>
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/g-extension-tp5101045p5101289.html
> To unsubscribe from g.extension -, click here<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5101045&code=Y3JhaWdhdW1hbm5AZ21haWwuY29tfDUxMDEwNDV8MTQzODE1ODA2Nw==>
> NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/g-extension-tp5101045p5101294.html
Sent from the Grass - Users mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140131/5228b16d/attachment-0001.html>
