[GRASS-user] g.extension -
Vaclav Petras
wenzeslaus at gmail.com
Fri Jan 31 13:59:01 PST 2014
On Fri, Jan 31, 2014 at 4:46 PM, caumann <craigaumann at gmail.com> wrote:
> The good news is that r58806 works!
> Bad news is that r58807 is giving the same errors as what I had before:
> ERROR: LOCATION </home/caumann/Desktop/<UNKNOWN>> not available
> Traceback (most recent call last):
> File "/usr/local/grass-7.0.svn/etc/gui/wxpython/gis_set.py", line 48, in
> <module>
> from gui_core.dialogs import TextEntryDialog
> File "/usr/local/grass-7.0.svn/etc/gui/wxpython/gui_core/dialogs.py",
> line 49, in <module>
> from gui_core.gselect import LocationSelect, MapsetSelect, Select, \
> File "/usr/local/grass-7.0.svn/etc/gui/wxpython/gui_core/gselect.py",
> line 59, in <module>
> import grass.temporal as tgis
> File "/usr/local/grass-7.0.svn/etc/python/grass/temporal/__init__.py",
> line 29, in <module>
> from temporal_vector_algebra import *
> File
> "/usr/local/grass-7.0.svn/etc/python/grass/temporal/temporal_vector_algebra.py",
> line 436, in <module>
> Anyways - I'm a tad happier now and thanks for everyone's help!
> And thank you for testing. This at least point us to some direction.
Vaclav
> On Fri, Jan 31, 2014 at 2:08 PM, wenzeslaus [via OSGeo.org] <[hidden
> email] <http://user/SendEmail.jtp?type=node&node=5101294&i=0>> wrote:
>> On Fri, Jan 31, 2014 at 3:56 PM, Craig Aumann <[hidden email]<http://user/SendEmail.jtp?type=node&node=5101289&i=0>
>> > wrote:
>>> Ok - so to work around the problem I compiled GRASS 70 with the
>>> following flags following the instructions at
>>> http://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu#GRASS_GIS
>>> Not seeing any compilation errors.
>>> CFLAGS="-O2 -Wall" LDFLAGS="-s" ./configure \
>>> --enable-largefile=yes \
>>> --enable-64bit \
>>> --with-libs=/usr/lib \
>>> --with-nls \
>>> --with-cxx \
>>> --with-proj-share=/usr/share/proj \
>>> --with-geos=/usr/bin/geos-config \
>>> --with-readline \
>>> --with-python=yes \
>>> --with-wxwidgets \
>>> --with-cairo \
>>> --with-opengl-libs=/usr/include/GL \
>>> --with-motif \
>>> --with-tcltk-includes="/usr/include/tcl8.5" \
>>> --with-ffmpeg=yes --with-ffmpeg-includes="/usr/include/libavcodec
>>> /usr/include/libavformat /usr/include/libswscale /usr/include/libavutil" \
>>> --with-freetype=yes --with-freetype-includes="/usr/include/freetype2/" \
>>> --with-postgres=no \
>>> --with-postgresql=no \
>>> --with-sqlite=yes \
>>> --with-mysql=no \
>>> --with-odbc=no
>>> When I start grass 70 I get:
>>> Hit RETURN to continue
>>> Starting GRASS GIS...
>>> access: No such file or directory
>>> ERROR: LOCATION </home/caumann/<UNKNOWN>> not available
>>> in <module>
>>> File
>>> m_overlay = pygrass.Module('v.overlay', quiet=True, run_=False)
>>> File
>>> "/usr/local/grass-7.0.svn/etc/python/grass/pygrass/modules/interface/module.py",
>>> line 252, in __init__
>>> tree = fromstring(self.xml)
>>> File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1302, in XML
>>> return parser.close()
>>> File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1655, in close
>>> self._raiseerror(v)
>>> File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1507, in
>>> _raiseerror
>>> raise err
>>> xml.etree.ElementTree.ParseError: no element found: line 1, column 0
>>> Error in GUI startup. If necessary, please report this error to the
>>> GRASS developers.
>>> Switching to text mode now.
>>> Hit RETURN to continue...
>>> ^CTraceback (most recent call last):
>>> File "/usr/local/bin/grass70", line 1324, in <module>
>>> set_data()
>>> File "/usr/local/bin/grass70", line 679, in set_data
>>> gui_startup()
>>> File "/usr/local/bin/grass70", line 700, in gui_startup
>>> sys.stdin.readline()
>>> KeyboardInterrupt
>>> What did I forget to include???
>>> You did everything right and you discovered another bug. I unfortunately
>> cannot reproduce it (Ubuntu 12.04).
>> Try please GRASS revision 58806:
>> svn up -r58806
>> make distclean
>> ./configure...
>> make
>> ./bin.../grass70
>> and if it will work (and you will have still strength to continue) please
>> try also revision 58807.
>>> grass-user mailing list
>>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5101289&i=1>
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5101289&i=2>
>> If you reply to this email, your message will be added to the
>> discussion below:
>> http://osgeo-org.1560.x6.nabble.com/g-extension-tp5101045p5101289.html
>> To unsubscribe from g.extension -, click here.
>> NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: g.extension -<http://osgeo-org.1560.x6.nabble.com/g-extension-tp5101045p5101294.html>
> Sent from the Grass - Users mailing list archive<http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html>at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140131/bffe484d/attachment.html>
