[GRASS-user] grass 6.4.3 and db.connect
Paul Shapley
p.shapley at gmail.com
Fri Jan 31 13:43:07 PST 2014
I am using 'db.connect' to get access to a sqlite database. I have renamed
the database extension from '.sqlite' to '.db' and placed it in the
'PERMANENT' directory but not entirely sure if i've correctly set this
sqlite access up correctly. When i use 'db.test' i get the following error.
Unable to open database: unable to open database file
ERROR: Unable to open database
<'/home/username/dtm_location/PERMANENT/gisdata.db'>
ERROR: EXECUTE: ******** ERROR ********
I'm sure i'm probably making some simple errors in the configuration
somewhere. Can anyone help with setup?
Many thanks,
*Paul J. Shapley *
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140131/7c726cf0/attachment.html>
