[GRASS-user] [Qgis-user] Python modules problems after last OSX GIS updates
William Kyngesburye
woklist at kyngchaos.com
Tue Jul 1 06:20:23 PDT 2014
Is that within the GRASS GUI? That makes sense since Michael is probably still using the old Carbon wxpython, which has to run in 32 bit mode. My matplotlib is 64 bit only. I have problems getting it to compile both 32 and 64 bits.
On Jul 1, 2014, at 7:21 AM, Carlos Grohmann <carlos.grohmann at gmail.com> wrote:
> Hi there
> Sorry, my mistake
> It's the Dakota GIS Team who's using a VM. I'd just read that and it got stuck in my head.
> I re-checked it today and William's binaries are working fine (python complains about LucidaGrande fonte, but that's it):
> 2014-07-01 09:01:14.232 Python[21856:d0b] CoreText performance note: Client called CTFontCreateWithName() using name ".Lucida Grande UI" and got font with PostScript name ".LucidaGrandeUI". For best performance, only use PostScript names when calling this API.
> The problems are actually with Michael Barton's GRASS-7.0 binaries. (I want to look at the global MOLA dataset, so went with v7.0 since it already has the planetary bodies listed on the Location wizard)
> In it, I can import matplotlib, but this:
> import matplotlib.pyplot as plt
> gives me this:
> Traceback (most recent call last):
> File "<stdin>", line 1, in <module>
> File "/Library/Python/2.7/site-packages/matplotlib-override/matplotlib/pyplot.py", line 24, in <module>
> import matplotlib.colorbar
> File "/Library/Python/2.7/site-packages/matplotlib-override/matplotlib/colorbar.py", line 27, in <module>
> import matplotlib.artist as martist
> File "/Library/Python/2.7/site-packages/matplotlib-override/matplotlib/artist.py", line 8, in <module>
> from transforms import Bbox, IdentityTransform, TransformedBbox, \
> File "/Library/Python/2.7/site-packages/matplotlib-override/matplotlib/transforms.py", line 35, in <module>
> from matplotlib._path import (affine_transform, count_bboxes_overlapping_bbox,
> ImportError: dlopen(/Library/Python/2.7/site-packages/matplotlib-override/matplotlib/_path.so, 2): no suitable image found. Did find:
> /Library/Python/2.7/site-packages/matplotlib-override/matplotlib/_path.so: mach-o, but wrong architecture
> sorry about the confusion
> best
> Carlos
> On Mon, Jun 30, 2014 at 10:08 PM, Anna Petrášová <kratochanna at gmail.com> wrote:
> Hi,
> On Mon, Jun 30, 2014 at 7:57 PM, William Kyngesburye <woklist at kyngchaos.com> wrote:
> What are the errors? Do you have simple examples I can try? I updated matplotlib and GDAL a month ago and this is the first I've heard of problems. I am not packaging with a virtual machine.
> I did hear about GRASS problems. There are font warnings due to a slip in wxPython bugfixing - fixed for wx Carbon but not wx Cocoa. I am now using wxPython 3 Cocoa, and I read that there were fixes in GRASS for that version, but maybe there are other problems, or it may be an OS X thing.
> Regarding wxPython3 Cocoa, there is still a lot of problems. I found several tickets on wxWidgets which we are affected by and only for some of them there is a workaround. WxGUI works only to certain extent, but there are problems with dialog modality, map selection widget, toolbars and other pretty serious things. On the other hand, wxnviz seems to work pretty well, although switching back to 2D mode, makes the GUI unresponsive which is bug in a notebook widget, not wxNviz.
> On Jun 30, 2014, at 3:28 PM, Carlos Grohmann <carlos.grohmann at gmail.com> wrote:
> > Hello, apologies for cross-posting but this might be happening to other users
> > After installing the latest packages updates from William Kyngesburye on OSX 10.9 Mavericks, I'm getting lots of errors, both in Matplotlib and GDAL. From what I could see, that all return the "mach-o, but wrong architecture" error, so this might be related to William's recent setup for packaging using a virtual machine.
> > I'm also getting the some errors with wxpython running GRASS 6.4.4
> > Unfortunately for me, Matplotlib is pretty much essential, so I'm hoping this issues get fixed soon.
> sorry, no idea about this
> Anna
> > best
> > Carlos
> > Prof. Carlos Henrique Grohmann
> > Institute of Energy and Environment - Univ. of São Paulo, Brazil
> > - Digital Terrain Analysis | GIS | Remote Sensing -
> > http://carlosgrohmann.com
> > http://orcid.org/0000-0001-5073-5572
> > ________________
> > Can’t stop the signal.
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Those people who most want to rule people are, ipso-facto, those least suited to do it."
> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
> ________________
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
