[GRASS-user] [Qgis-user] Python modules problems after last OSX GIS updates
Carlos Grohmann
carlos.grohmann at gmail.com
Tue Jul 1 09:46:19 PDT 2014
I think you are right.
importing only matplotlib works, but pyplot doesn't, so it should related
to wxpython.
best
Carlos
On Tue, Jul 1, 2014 at 10:20 AM, William Kyngesburye <woklist at kyngchaos.com>
wrote:
> Is that within the GRASS GUI? That makes sense since Michael is probably
> still using the old Carbon wxpython, which has to run in 32 bit mode. My
> matplotlib is 64 bit only. I have problems getting it to compile both 32
> and 64 bits.
> On Jul 1, 2014, at 7:21 AM, Carlos Grohmann <carlos.grohmann at gmail.com>
> wrote:
> > Hi there
> > Sorry, my mistake
> > It's the Dakota GIS Team who's using a VM. I'd just read that and it got
> stuck in my head.
> > I re-checked it today and William's binaries are working fine (python
> complains about LucidaGrande fonte, but that's it):
> > 2014-07-01 09:01:14.232 Python[21856:d0b] CoreText performance note:
> Client called CTFontCreateWithName() using name ".Lucida Grande UI" and got
> font with PostScript name ".LucidaGrandeUI". For best performance, only use
> PostScript names when calling this API.
> > The problems are actually with Michael Barton's GRASS-7.0 binaries. (I
> want to look at the global MOLA dataset, so went with v7.0 since it already
> has the planetary bodies listed on the Location wizard)
> > In it, I can import matplotlib, but this:
> > import matplotlib.pyplot as plt
> > gives me this:
> > Traceback (most recent call last):
> > File "<stdin>", line 1, in <module>
> > File
> "/Library/Python/2.7/site-packages/matplotlib-override/matplotlib/pyplot.py",
> line 24, in <module>
> > import matplotlib.colorbar
> > File
> "/Library/Python/2.7/site-packages/matplotlib-override/matplotlib/colorbar.py",
> line 27, in <module>
> > import matplotlib.artist as martist
> > File
> "/Library/Python/2.7/site-packages/matplotlib-override/matplotlib/artist.py",
> line 8, in <module>
> > from transforms import Bbox, IdentityTransform, TransformedBbox, \
> > File
> "/Library/Python/2.7/site-packages/matplotlib-override/matplotlib/transforms.py",
> line 35, in <module>
> > from matplotlib._path import (affine_transform,
> count_bboxes_overlapping_bbox,
> > ImportError:
> dlopen(/Library/Python/2.7/site-packages/matplotlib-override/matplotlib/_path.so,
> 2): no suitable image found. Did find:
> /Library/Python/2.7/site-packages/matplotlib-override/matplotlib/_path.so:
> mach-o, but wrong architecture
> > sorry about the confusion
> > best
> > Carlos
> > On Mon, Jun 30, 2014 at 10:08 PM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
> > Hi,
> > On Mon, Jun 30, 2014 at 7:57 PM, William Kyngesburye <
> woklist at kyngchaos.com> wrote:
> > What are the errors? Do you have simple examples I can try? I updated
> matplotlib and GDAL a month ago and this is the first I've heard of
> problems. I am not packaging with a virtual machine.
> > I did hear about GRASS problems. There are font warnings due to a slip
> in wxPython bugfixing - fixed for wx Carbon but not wx Cocoa. I am now
> using wxPython 3 Cocoa, and I read that there were fixes in GRASS for that
> version, but maybe there are other problems, or it may be an OS X thing.
> > Regarding wxPython3 Cocoa, there is still a lot of problems. I found
> several tickets on wxWidgets which we are affected by and only for some of
> them there is a workaround. WxGUI works only to certain extent, but there
> are problems with dialog modality, map selection widget, toolbars and other
> pretty serious things. On the other hand, wxnviz seems to work pretty well,
> although switching back to 2D mode, makes the GUI unresponsive which is bug
> in a notebook widget, not wxNviz.
> > On Jun 30, 2014, at 3:28 PM, Carlos Grohmann <carlos.grohmann at gmail.com>
> wrote:
> > > Hello, apologies for cross-posting but this might be happening to
> other users
> > > After installing the latest packages updates from William Kyngesburye
> on OSX 10.9 Mavericks, I'm getting lots of errors, both in Matplotlib and
> GDAL. From what I could see, that all return the "mach-o, but wrong
> architecture" error, so this might be related to William's recent setup for
> packaging using a virtual machine.
> > > I'm also getting the some errors with wxpython running GRASS 6.4.4
> > > Unfortunately for me, Matplotlib is pretty much essential, so I'm
> hoping this issues get fixed soon.
> > sorry, no idea about this
> > Anna
> > > best
> > > Carlos
> > > Prof. Carlos Henrique Grohmann
> > > Institute of Energy and Environment - Univ. of São Paulo, Brazil
> > > - Digital Terrain Analysis | GIS | Remote Sensing -
> > > http://carlosgrohmann.com
> > > http://orcid.org/0000-0001-5073-5572
> > > ________________
> > > Can’t stop the signal.
> > > _______________________________________________
> > > Qgis-user mailing list
> > > Qgis-user at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/qgis-user
> > William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> > http://www.kyngchaos.com/
> > "Those people who most want to rule people are, ipso-facto, those least
> suited to do it."
> > - A rule of the universe, from the HitchHiker's Guide to the Galaxy
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
> > ________________
> "Time is an illusion - lunchtime doubly so."
> - Ford Prefect
________________
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140701/72ebd099/attachment.html>
