[GRASS-user] r.profile
Mark Seibel mseibel at gmail.com
Thu Jul 3 07:26:56 PDT 2014
Thanks for the help!  Logged an update.
Mark
On Thu, Jul 3, 2014 at 9:31 AM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Thu, Jul 3, 2014 at 8:10 AM, Mark Seibel <mseibel at gmail.com> wrote:
>>> This is a long standing problem (for me anyway) - see thread from 2012
>>> https://www.mail-archive.com/grass-dev@lists.osgeo.org/msg26480.html
>> How can I determine if this is an active ticket, so I can create one if
>> need be?
> Search through GRASS Trac instance, i.e. this website:
> http://trac.osgeo.org/grass/
> Simple search:
> http://trac.osgeo.org/grass/search
> Advanced search (aka Custom query):
> trac.osgeo.org/grass/query
> However, in your case you know the ticket number (usually prefixed with
> #), so search for it (#1787) or just add the number to the end of the URL:
> http://trac.osgeo.org/grass/ticket/1787
> Also, if you found an email with the ticket (copy of ticket message was
> sent to mailing list), you should find a link to the ticket at the bottom
> of the message.
> The ticket status is in parentheses after the ticket number.
> If the ticket is older without activity, you may want to write there that
> you are also affected and specify your system and other related details.
> You need OSGeo ID to be able to login to the GRASS Trac and create and
> modify tickets.
> http://www.osgeo.org/osgeo_userid
> Vaclav
> Thanks
>> Mark
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140703/4b187a26/attachment.html>
