[GRASS-user] problems with installation of grass 7
Raphael.Viscarra-Rossel at csiro.au
Tue Jul 22 22:00:53 PDT 2014
Hello,
I downloaded grass 7.0(beta) from http://grass.osgeo.org/download/software/mac-osx/ and all the framework packages too.
Installed them but I cannot get the grass7 guy to run. Errors are below.
Launching <wxpython> GUI in the background, please wait...
GRASS 7.0.0svn (Meander):~ >
GRASS 7.0.0svn (Meander):~ > Unable to import pyGRASS: dlopen(/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib/libgrass_raster.7.0.0svn.dylib, 10): Symbol not found: _GEOSDelaunayTriangulation
Referenced from: /Library/Frameworks/SQLite3.framework/Versions/B/SQLite3
Expected in: /Library/Frameworks/GEOS.framework/Versions/3/GEOS
in /Library/Frameworks/SQLite3.framework/Versions/B/SQLite3
Some functionality will be not accessible
File "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/gui/wxpython/wxgui.py", line 34, in <module>
from lmgr.frame import GMFrame
File "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/gui/wxpython/lmgr/frame.py", line 50, in <module>
from lmgr.layertree import LayerTree, LMIcons
File "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/gui/wxpython/lmgr/layertree.py", line 37, in <module>
from mapdisp.frame import MapFrame
File "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/gui/wxpython/mapdisp/frame.py", line 35, in <module>
from vdigit.toolbars import VDigitToolbar
File "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/gui/wxpython/vdigit/toolbars.py", line 30, in <module>
from iclass.digit import IClassVDigit
File "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/gui/wxpython/iclass/digit.py", line 23, in <module>
from vdigit.wxdisplay import DisplayDriver, TYPE_AREA
ImportError: cannot import name TYPE_AREA
I could not find resolution to this problem on the web. Has anyone come across this and overcome it?
Thank you
Raphael
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140723/4c0cc79f/attachment.html>
