[GRASS-user] problems with installation of grass 7
Markus Neteler
neteler at osgeo.org
Tue Jul 22 23:19:55 PDT 2014
you need to install the GEOS framework as well or the version of it which
had been used to prepare the GRASS binaries.
Markus
On Jul 23, 2014 7:01 AM, <Raphael.Viscarra-Rossel at csiro.au> wrote:
> Hello,
> I downloaded grass 7.0(beta) from
> http://grass.osgeo.org/download/software/mac-osx/ and all the framework
> packages too.
> Installed them but I cannot get the grass7 guy to run. Errors are below.
> Launching <wxpython> GUI in the background, please wait...
> GRASS 7.0.0svn (Meander):~ >
> GRASS 7.0.0svn (Meander):~ > Unable to import pyGRASS:
> dlopen(/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib/libgrass_raster.7.0.0svn.dylib,
> 10): Symbol not found: _GEOSDelaunayTriangulation
> Referenced from: /Library/Frameworks/SQLite3.framework/Versions/B/SQLite3
> Expected in: /Library/Frameworks/GEOS.framework/Versions/3/GEOS
> in /Library/Frameworks/SQLite3.framework/Versions/B/SQLite3
> Some functionality will be not accessible
> Traceback (most recent call last):
> File
> "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/gui/wxpython/wxgui.py",
> line 34, in <module>
> from lmgr.frame import GMFrame
> File
> "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/gui/wxpython/lmgr/frame.py",
> line 50, in <module>
> from lmgr.layertree import LayerTree, LMIcons
> File
> "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/gui/wxpython/lmgr/layertree.py",
> line 37, in <module>
> from mapdisp.frame import MapFrame
> File
> "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/gui/wxpython/mapdisp/frame.py",
> line 35, in <module>
> from vdigit.toolbars import VDigitToolbar
> File
> "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/gui/wxpython/vdigit/toolbars.py",
> line 30, in <module>
> from iclass.digit import IClassVDigit
> File
> "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/gui/wxpython/iclass/digit.py",
> line 23, in <module>
> from vdigit.wxdisplay import DisplayDriver, TYPE_AREA
> ImportError: cannot import name TYPE_AREA
> I could not find resolution to this problem on the web. Has anyone come
> across this and overcome it?
> Thank you
> Raphael
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140723/5007f55d/attachment-0001.html>
