[GRASS-user] problems with installation of grass 7
Raphael.Viscarra-Rossel at csiro.au
Wed Jul 23 00:21:50 PDT 2014
Hello Markus,
Thank you for the response. That fixed that. Now, I have another message (below). The gui starts ok though and I can open a project and map set. However, when I add my raster map to display, it does not display at all. I can see the histogram of the data but not the map.
Is the message I get is this – related to the problem I am having?:
Launching <wxpython> GUI in the background, please wait...
GRASS 7.0.0svn (Aus1km):~ > objc[15362]: Class TSSandboxPrefs is implemented in both /Library/Frameworks/TSLicense.framework/Versions/A/TSLicense and /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import. One of the two will be used. Which one is undefined.
objc[15362]: Class TSSandboxPrefs is implemented in both /Library/Frameworks/TSLicense.framework/Versions/A/TSLicense and /Library/QuickTime/Flip4Mac WMV Advanced.component/Contents/MacOS/Flip4Mac WMV Advanced. One of the two will be used. Which one is undefined.
Thank you. Raphael.
From: Markus Neteler <neteler at osgeo.org<mailto:neteler at osgeo.org>>
Date: Wednesday, 23 July 2014 4:19 pm
To: "Viscarra Rossel, Raphael (L&W, Black Mountain)" <Raphael.Viscarra-Rossel at csiro.au<mailto:Raphael.Viscarra-Rossel at csiro.au>>
Cc: "grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>" <grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>>
Subject: Re: [GRASS-user] problems with installation of grass 7
you need to install the GEOS framework as well or the version of it which had been used to prepare the GRASS binaries.
Markus
On Jul 23, 2014 7:01 AM, <Raphael.Viscarra-Rossel at csiro.au<mailto:Raphael.Viscarra-Rossel at csiro.au>> wrote:
Hello,
I downloaded grass 7.0(beta) from http://grass.osgeo.org/download/software/mac-osx/ and all the framework packages too.
Installed them but I cannot get the grass7 guy to run. Errors are below.
GRASS 7.0.0svn (Meander):~ >
GRASS 7.0.0svn (Meander):~ > Unable to import pyGRASS: dlopen(/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib/libgrass_raster.7.0.0svn.dylib, 10): Symbol not found: _GEOSDelaunayTriangulation
Referenced from: /Library/Frameworks/SQLite3.framework/Versions/B/SQLite3
Expected in: /Library/Frameworks/GEOS.framework/Versions/3/GEOS
in /Library/Frameworks/SQLite3.framework/Versions/B/SQLite3
Some functionality will be not accessible
File "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/gui/wxpython/wxgui.py", line 34, in <module>
from lmgr.frame import GMFrame
File "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/gui/wxpython/lmgr/frame.py", line 50, in <module>
from lmgr.layertree import LayerTree, LMIcons
File "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/gui/wxpython/lmgr/layertree.py", line 37, in <module>
from mapdisp.frame import MapFrame
File "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/gui/wxpython/mapdisp/frame.py", line 35, in <module>
from vdigit.toolbars import VDigitToolbar
File "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/gui/wxpython/vdigit/toolbars.py", line 30, in <module>
from iclass.digit import IClassVDigit
File "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/gui/wxpython/iclass/digit.py", line 23, in <module>
from vdigit.wxdisplay import DisplayDriver, TYPE_AREA
ImportError: cannot import name TYPE_AREA
I could not find resolution to this problem on the web. Has anyone come across this and overcome it?
Thank you
Raphael
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140723/7b2db0f1/attachment.html>
