[GRASS-user] t.rast.list use
Sören Gebbert
soerengebbert at googlemail.com
Fri Jul 25 13:45:19 PDT 2014
Hi Veronica,
sorry for the late response.
You can use the datetime[1] functionality of sqlite to perform this
task, this should work for Jannuary:
t.rast.list input=cla_null_mayor65 where='start_time >=
datetime(start_time, "start of year") and start_time <=
datetime(start_time, "start of year", "1 month")'
[1] https://www.sqlite.org/lang_datefunc.html
Best regards
Soeren
2014-06-17 20:40 GMT+02:00 Veronica Andreo <veroandreo at gmail.com>:
> Hi list!
> I have a strds with 506 maps that correspond to 8-day composite products (11
> years).
> I want to get the list of maps where start_month is january, february and so
> on... to use as input in r.series (or t.rast.series), but i'm not finding
> the way to do that...
> i don't want to aggregate maps by month, i need to use the original maps
> belonging to each month... is there a way to obtain that (aside from
> manually :P)??
> Till now the only query that has worked in the desired direction is:
> t.rast.list input=cla_null_mayor65 where="start_time >= '2003-01' and
> start_time <= '2003-02'"
> cla_null_mayor65_1|clorofila|2003-01-01 00:00:00|2003-01-09 00:00:00
> cla_null_mayor65_2|clorofila|2003-01-09 00:00:00|2003-01-17 00:00:00
> cla_null_mayor65_3|clorofila|2003-01-17 00:00:00|2003-01-25 00:00:00
> cla_null_mayor65_4|clorofila|2003-01-25 00:00:00|2003-02-02 00:00:00
> but that's only for january 2003... and i would need january 2004, 2005...
> 2013 in the same list... when i add more clauses to the "where" query it
> stops working...
> What would be the right approach here?
> THANKS MUCH IN ADVANCE!
> Best,
> Vero
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
