[GRASS-user] t.rast.list use
Veronica Andreo
veroandreo at gmail.com
Sat Jul 26 08:42:02 PDT 2014
Hi Sören, everyone!
Thanks for the answer!
Eventually (after having done it in much more "artisanal" manner, of
course! :)), I found a way of doing what I wanted by means of "strftime" in
a link Anna posted once [1].
This is more or less what I did, maybe useful for someone else or as
examples in manuals:
### check maps i was using as inputs
# for a single month
t.rast.list input=my_strds where="strftime('%m', start_time)='01'"
# loop for all months
for i in 01 02 03 04 05 06 07 08 09 10 11 12 ; do
t.rast.list input=my_strds where="strftime('%m', start_time)='${i}'" >
list_${i}
done
### then, applied the selection in t.rast.series
t.rast.series input=my_strds method=average output=average_01 \
# and loop over for different months and methods
for m in average median stddev range minimum maximum ; do
t.rast.series input=my_strds method=${m} where="strftime('%m',
start_time)='${i}'" output=${m}_${i}
done
done
Best,
Vero
[1] http://courses.ncsu.edu/mea592/common/Assign_GISmdmodel/a_temporal.html
2014-07-25 17:45 GMT-03:00 Sören Gebbert <soerengebbert at googlemail.com>:
> Hi Veronica,
> sorry for the late response.
> You can use the datetime[1] functionality of sqlite to perform this
> task, this should work for Jannuary:
> t.rast.list input=cla_null_mayor65 where='start_time >=
> datetime(start_time, "start of year") and start_time <=
> datetime(start_time, "start of year", "1 month")'
> [1] https://www.sqlite.org/lang_datefunc.html
> Best regards
> Soeren
> 2014-06-17 20:40 GMT+02:00 Veronica Andreo <veroandreo at gmail.com>:
> > Hi list!
> > I have a strds with 506 maps that correspond to 8-day composite products
> (11
> > years).
> > I want to get the list of maps where start_month is january, february
> and so
> > on... to use as input in r.series (or t.rast.series), but i'm not finding
> > the way to do that...
> > i don't want to aggregate maps by month, i need to use the original maps
> > belonging to each month... is there a way to obtain that (aside from
> > manually :P)??
> > Till now the only query that has worked in the desired direction is:
> > t.rast.list input=cla_null_mayor65 where="start_time >= '2003-01' and
> > start_time <= '2003-02'"
> > cla_null_mayor65_1|clorofila|2003-01-01 00:00:00|2003-01-09 00:00:00
> > cla_null_mayor65_2|clorofila|2003-01-09 00:00:00|2003-01-17 00:00:00
> > cla_null_mayor65_3|clorofila|2003-01-17 00:00:00|2003-01-25 00:00:00
> > cla_null_mayor65_4|clorofila|2003-01-25 00:00:00|2003-02-02 00:00:00
> > but that's only for january 2003... and i would need january 2004,
> 2005...
> > 2013 in the same list... when i add more clauses to the "where" query it
> > stops working...
> > What would be the right approach here?
> > THANKS MUCH IN ADVANCE!
> > Best,
> > Vero
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140726/2203d4cd/attachment.html>
