[GRASS-user] t.rast.mapcalc error
Veronica Andreo
veroandreo at gmail.com
Sun Jul 27 14:24:01 PDT 2014
Hi Soeren, Markus and list,
I'm having trouble with t.rast.mapcalc... these are the commands I'm using:
# get the max value for each pixel in the strds
t.rast.series input=my_strds method=maximum output=max_my_strds
# then, i need to compare all values in the strds with the map of maximums
and whenever it's the same value, save the start_doy, otherwise null
t.rast.mapcalc -n inputs=my_strds output=date_max_my_strds \
expression="if(my_strds == max_my_strds,start_doy(),null())"
basename=date_max_my_strds
# to get a map with dates of maximum values afterwards
t.rast.series input=date_max_my_strds method=maximum
output=series_date_max_my_strds
This is the error I'm getting in newly compiled GRASS 7
Start temporal sampling
Start mapcalc computation
Invalid map <max_cla_hants25_corrected_1>
Parse error
ERROR: parse error
ERROR: Error while mapcalc computation
However, when i follow the exact same steps, but using an older map of
maximums (created a month ago or so), it works just fine... that's the only
difference i've found... this used to work a couple of weeks ago...
Am I doing something wrong? Or is it no longer possible to compare all maps
in strds with a single map??? Please, help!
Thanks much in advance!
Best,
Vero
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140727/e53db437/attachment.html>
