[GRASS-user] uploading R data in GRASS GIS
Helmut Kudrnovsky
hellik at web.de
Mon Jun 9 02:09:28 PDT 2014
Bleninger, Sara wrote
> Hi,
> I am quite unfamiliar to GRASS GIS, so I hope, that the following question
> is not too elementary...
> There are two datasets:
> - a shapefile consisting of geographical information to create a
> map of regions, the last column is a code for the regions
> - a file of results of R computations. The units are the regions
> that are coded in the shapefile. Here the code for regions is the first
> column. It is possible to store this file in several formats.
> It is possible to upload the shapefile data in GRASS and make the map of
> regions. Now, I want to color the map according to the R results. How can
> I connect the R results information to the mapping information and color
> the map?
> Thanks for your help!
> Sara
> grass-user mailing list
> grass-user at .osgeo
> http://lists.osgeo.org/mailman/listinfo/grass-user
maybe post your question also in grass-stats [1]
[1] http://lists.osgeo.org/mailman/listinfo/grass-stats
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/uploading-R-data-in-GRASS-GIS-tp5144667p5144759.html
Sent from the Grass - Users mailing list archive at Nabble.com.
