[GRASS-user] g.gui.animation - temporal mode
Annalisa Minelli
annagrass6 at gmail.com
Tue Jun 17 06:37:52 PDT 2014
Thanks Anna,
it works! and in the end I was able to open the animation correctly (with
time intervals on the slider) by command line too - using the
line: "g.gui.animation stvds='traffic at tbretagne5'"
but now I have some new tricks.. I would like to:
* configure the vector temporal maps with the appropriate colors/selections
- I'd need a sort of d.vect before launching/recording the animation and I
was able to do it interactively but not by commandline..
* add a vector map layer as background (a coastline), but if I run
something like: "g.gui.animation vect='coast' stvds='traffic at tbretagne5'"
it says me that vect and stvds are mutually exclusive, again, I was able to
do it only itneractively
* export the animation (by commandline)
Many thanks,
Annalisa
2014-06-17 6:28 GMT+02:00 Anna Petrášová <kratochanna at gmail.com>:
> Hi,
> On Mon, Jun 16, 2014 at 6:03 AM, Annalisa Minelli <annagrass6 at gmail.com>
> wrote:
>> Hi list,
>> a very simple, maybe dumb, question: I'm trying to set up an animation
>> using some vector files (registered in a spatio temporal vector dataset).
>> Evenif the aim of my analysis is to do it by command line, I tried to
>> reproduce this first interactively.
>> In the end I was able to obtain an animation, but I had not the slider
>> reporting the temporal information (I got only informations about the
>> frames 1/6, 2/6 etc etc).
>> How can I switch to the "temporal mode", since if I go into the "adjust
>> speed of animation" I can manage only the "simple mode" tools (temporal
>> mode remains grey)?
> when you are adding the series, there is a dropdown list where you select
> space-time raster dataset (not series of raster maps). Then you select the
> particular dataset as one name. That should do the trick.
> Anna
>> Thanks in advance,
>> Annalisa
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140617/97c4e29a/attachment-0001.html>
