[GRASS-user] g.gui.animation - temporal mode
Anna Petrášová
kratochanna at gmail.com
Mon Jun 16 21:28:30 PDT 2014
On Mon, Jun 16, 2014 at 6:03 AM, Annalisa Minelli <annagrass6 at gmail.com>
wrote:
> Hi list,
> a very simple, maybe dumb, question: I'm trying to set up an animation
> using some vector files (registered in a spatio temporal vector dataset).
> Evenif the aim of my analysis is to do it by command line, I tried to
> reproduce this first interactively.
> In the end I was able to obtain an animation, but I had not the slider
> reporting the temporal information (I got only informations about the
> frames 1/6, 2/6 etc etc).
> How can I switch to the "temporal mode", since if I go into the "adjust
> speed of animation" I can manage only the "simple mode" tools (temporal
> mode remains grey)?
when you are adding the series, there is a dropdown list where you select
space-time raster dataset (not series of raster maps). Then you select the
particular dataset as one name. That should do the trick.
Anna
> Thanks in advance,
> Annalisa
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140617/b73eca58/attachment.html>
