[GRASS-user] wxgui fails using scripts
Markus Neteler neteler at osgeo.org
Tue Jun 17 10:26:48 PDT 2014
Dave,
On Mon, Jun 16, 2014 at 9:59 PM, Dave Roberts
>     Then simply "sh litho.sh" would produce the reuslts I wanted, and if I
> decided on a different color scheme it was a trival matter to edit the file.
>    In wxgui this no longer works, as after the first one or two lines GRASS
> reponds with
Did you try the standalone monitor?
d.mon wx0
(also wx1, wx2 etc)
It still suffers from being very slow but should "listen" to the command line.
Markus
