[GRASS-user] wxgui fails using scripts
Dave Roberts
dvrbts at ecology.msu.montana.edu
Wed Jun 18 06:09:58 PDT 2014
Hi Markus,
Sorry, I misspoke. I did mean wx0. I work from the command line,
not the full GUI. I think of wx0 as also a GUI due to the toolbar at
the top.
Even the simple script below occasionally fails on the d.vect command
d.erase
g.region study
d.his h=elev i=hillshd
d.vect boundary type=boundary col=white
Dave
On 06/17/2014 11:26 AM, Markus Neteler wrote:
> Dave,
> On Mon, Jun 16, 2014 at 9:59 PM, Dave Roberts
>> Then simply "sh litho.sh" would produce the reuslts I wanted, and if I
>> decided on a different color scheme it was a trival matter to edit the file.
>> In wxgui this no longer works, as after the first one or two lines GRASS
>> reponds with
> Did you try the standalone monitor?
> d.mon wx0
> (also wx1, wx2 etc)
> It still suffers from being very slow but should "listen" to the command line.
> Markus
David W. Roberts office 406-994-4548
Professor and Head FAX 406-994-3190
Department of Ecology email droberts at montana.edu
Montana State University
Bozeman, MT 59717-3460
