[GRASS-user] v.lidar.growing.exe stops
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Thu Jun 19 04:24:06 PDT 2014
Hi Simon,
Do you get any error in the command window? Does your computer freeze or
slowing down before the message?
Cheers,
Saber
[mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of Crutchley, Simon
Sent: 19 June 2014 12:21
To: 'grass-user at lists.osgeo.org'
Subject: [GRASS-user] v.lidar.growing.exe stops
I've created a file using v.lidar.edgedetection but when I run
v.lidar.growing it runs for a while then I get a Windows message saying it
has "stopped working" and forces closure. I get no error in GRASS. This is
my command line - v.lidar.growing input=veg_edge2 at PERMANENT
output=lidar_edge_1 first=D149660_Petx at PERMANENT. Any suggestions?
Simon
This e-mail (and any attachments) is confidential and may contain personal
views which are not the views of English Heritage unless specifically
stated. If you have received it in error, please delete it from your system
and notify the sender immediately. Do not use, copy or disclose the
information in any way nor act in reliance on it. Any information sent to
English Heritage may become publicly available.
Portico: your gateway to information on sites in the National Heritage
Collection; have a look and tell us what you think.
http://www.english-heritage.org.uk/professional/archives-and-collections/por
tico/
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
If this email contains a quote or offer to sell products, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140619/3b88f574/attachment.html>
