[GRASS-user] Raster Mask under version 7 causes map to go white
Markus Neteler neteler at osgeo.org
Thu Jun 19 22:21:23 PDT 2014
Chris,
On Thu, Jun 19, 2014 at 3:32 AM,  <cboscari at sbcglobal.net> wrote:
> Hi Everyone,
> I am having an issue that I can’t seem to resolve using the beta2 version
> under both Windows or Linux, as well as daily snapshots  under the Ubuntu
> version.
> Basically, a raster mask file that I am using under the current version of
> grass 7 beta  “blanks” out the underlying raster- that is the entire display
> area is white, although both rasters (my raster map and the mask) appear as
> layers. If I remove the mask, the map area is again entirely visible.
Did you actually query the map(s)?
> It worked correctly back in December with the stable version as well as the
> snapshot of version 7 (then). Now the mask only works under 6.4.
> I am have looked on the website and the documentation to see if there were
> any changes made to raster masks, but am unable to find any changes.
The raster mask management is pretty much the same for years.
Perhaps it is just related to the color table you use?
Markus
