[GRASS-user] calculation valley floor width in GRASS or some index indicating valley floor width?
Helmut Kudrnovsky
hellik at web.de
Sun Jun 22 16:36:41 PDT 2014
SBL wrote
> Hei Helumt,
> In that case I would probably try r.param.scale in order to identify flat
> areas at maybe different scale levels.
> V-valleys have a higher variation in aspect at the bottom (sides are
> almost facing each other and nearly "meet" at the lowest point in a
> V-valley). While sides are more or less steep. So slope and aspect at a
> coarser level (also available through r.param.scale) could help to
> distinguish V- and U-valleys.
> Depending on scale U-Valleys have a TPI of ~0 at the bottom and ~0 at the
> middle of the sides (equaly much terrain above and below a focal cell in
> the given neighborhood).
> Some background material on TPI can be found here:
> http://www.jennessent.com/arcview/tpi.htm
> Jenness used ArcView. Yet TPI is a simple combination of r.neighbors and a
> mapcalc.
> Good luck with your modelling.
as a possible additional parameter for such a modelling, I've tried to
implement a Multi-resolution Valley Bottom Flatness (MrVBF) index.
http://lists.osgeo.org/pipermail/grass-commit/2014-June/031834.html
Author: hellik
Date: 2014-06-22 16:04:15 -0700 (Sun, 22 Jun 2014)
New Revision: 60919
Added:
grass-addons/grass7/raster/r.valley.bottom/
grass-addons/grass7/raster/r.valley.bottom/Makefile
grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.html
grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py
r.valley.bottom: a script to calculate a Multi-resolution Valley Bottom
testing and hints for improvement are very welcome.
thanks
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/calculation-valley-floor-width-in-GRASS-or-some-index-indicating-valley-floor-width-tp5132402p5147233.html
Sent from the Grass - Users mailing list archive at Nabble.com.
