[GRASS-user] how to create a Finite Element mesh from XY data?
Vishal Mehta
vishalm1975 at gmail.com
Fri Jun 27 16:12:22 PDT 2014
hi all,
I need to re-create a finite element mesh from XY data, (from input files
for a groundwater model someone else built in a different platform (IWFM).
Would appreciate some help in figuring out how to take the 2 files below,
and create a polygon vector layer with element ID assigned to polygons.
The nodes and elements are in 2 files, here is what they look like:
1. nodes file has node id, x,y (utm 10 wgs 84 i think), and a region id
*C Groundwater Node LocationsC The following lists
the node number and x & y coordinate of each nodeCC ID; Groundwater
node numberC X,Y; Coordinates of groundwater node location;
[L]CC-------------------------------------------------------------------------------C
Node ----------Coordinates----------C ID
X
YC-------------------------------------------------------------------------------
1 563734 4308465 2 565407
4308558 3 566687 4308507 4
567636 4308465*
2. element files links the nodes to element ids
File Description
C
C This file contains the element configuration for each element.
C The nodes that make a finite element are listed for each element in
C a counter-clock wise fashion starting with any node. For triangular
elements,
C the fourth node is specified as zero.
C
C
C For example,
C
C 13-------------14----------17
C I I I
C I 2 I 3 I
C I I I
C I I I
C 15------------- 16
C
C
C The configuration for elements 2 and 3 will be listed as,
C
C element node 1 node 2 node 3 node 4
C 2 13 15 16 14
C 3 14 16 17 0
C Element ------------Corresponding Nodes------------------
Subregion
C IE IDE(1) IDE(2) IDE(3) IDE(4)
IRGE
1 1 5 6 2
1
2 3 2 6 7
1
3 3 7 8 4
1
4 11 6 5 10
1
5 11 12 7 6
1
6 12 16 8 7
1
7 13 9 17 0
1
Thanks for any help!
Vishal
Vishal K. Mehta, PhD
Sr. Scientist
Stockholm Environment Institute - US
133 D St Suite F
Davis CA 95616
www.sei-us.org
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140627/474efc93/attachment.html>
