[GRASS-user] Fwd: FW: connecting to postgresql and postgis backend database - Grass 6.4.4svn
Paul Shapley
p.shapley at gmail.com
Fri Mar 21 05:50:21 PDT 2014
I'm having some problems with password authentication when trying to
connect to postgresql.
Here is the generated error:
(Fri Mar 21 10:25:16
2014)
g.remove vect=building at PERMANENT
Removing vector <building at PERMANENT>
DBMI-Postgres driver error:
Cannot connect to Postgres: FATAL: password authentication
failed for user "pshapley"
WARNING: Unable to open database <postgis> by driver <pg>
WARNING: Unable open database <postgis> by driver <pg>
WARNING: Unable to find table <npt_planning.building> linked to vector map
<building>
WARNING: couldn't be removed
WARNING: <building> nothing removed
(Fri Mar 21 10:25:17 2014) Command finished (0 sec)
Is this problem linked with Ticket #1274 because if i use 'v.in.ogr' (with
the -t) option
it imports all the geometries without the attributes (not much use)?. When
the import is finished
I am asked to 'try to rebuild topologies with v.build' but this does not
work.
Any ideas would be great.
Thanks,
*Paul Shapley*
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140321/050b0c3e/attachment.html>
