[GRASS-user] Elevation differences between endpoints of least cost paths
jctorres jctorres at ugr.es
Sat Mar 22 00:04:02 PDT 2014
Hi Don
I think you can solve this using grass 7 (you can download it from
http://grass.osgeo.org/download/software/). This version includes a new
option for r.cost that copies the value of the nearest cell. You can
solve the problem using
r.mapcalc "streamH=if(isnull(stream.thin),null(),FD)"
r.cost -k input=area.one output=dtv start_rast=streamH nearest=nearestH
nearestH will contains the elevation of the nearest stream
Best regards
Juan Carlos Torres                      | http://lsi.ugr.es/~jctorres
Laboratorio de Realidad Virtual         | Tlf.: (+34) 645 885 167
Dpto. Lenguajes y Sistemas Informaticos |       (+34) 958 249 307
ETS. Ing. Informatica                   |     interno ugr  71 260
Univ. de Granada                        | FAX: (+34) 958 243 179
El 21/03/14 23:47, MacQueen, Don escribió:
> I'm stating with a DEM (named FD).
> First I find streams:
>    r.watershed elevation=FD stream=stream
>    r.thin input=stream output=stream.thin
> Then, for each point on the DEM, I need
>   The distance to the nearest point in a stream
>   The elevation difference to the stream point
> I can get the distance by gollowing the example "Computing a distance map"
> in Neteler & Mitasova's GRASS book:
>    r.mapcalc area.one=1
>    r.cost -k input=area.one output=dtv start_rast=stream.thin
> So far so good, and the results make sense
> But I would very much appreciate suggestions for the elevation difference.
> I have been looking at various r.* routines, such as r.drain, but haven't
> yet found a solution. I have very little experience with raster analysis.
> (and in fact, I'm using the R package spgrass6 to manage the above steps)
> Thanks
> -Don
------------ pr?xima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140322/86ebbf80/attachment.html>
