[GRASS-user] [GRASS-dev] Problems 3D rendering with WxNviz (Ubuntu)
Johannes Radinger johannesradinger at gmail.com
Wed Mar 26 02:27:54 PDT 2014
I just reinstalled wxPython and recompiled GRASS to be sure that I am
working with the newest versions.
The problem still persists. Here how I installed wxPython:
  sudo apt-get install python-wxgtk2.8 python-wxtools wx2.8-doc
wx2.8-examples wx2.8-headers wx2.8-i18n
and then I also followed another procedure explained here:
http://stackoverflow.com/questions/14007557/installing-wxpython-on-ubuntu-12-04
   1. First make sure that you have Python installed
   2. Install wxGTK 2.8 with the command, 'sudo apt-get install
   python-wxgtk2.8'
   3. Run the command, 'apt-get source -d wxwidgets2.8'
   4. Now run, 'dpkg-source -x wxwidgets2.8_2.8.12.1-6ubuntu2.dsc'
   5. cd wxwidgets2.8-2.8.12.1
   6. cd wxPython
   7. Now run the command, 'sudo python setup.py install'
   8. wxPython and wxWidgets are now successfully installed!
Now it seems that two versions are installed
>>> import wxversion
>>> wxversion.getInstalled()
['2.8-gtk2-unicode', '2.8-gtk2-unicode']
Does that help?
Is there a way the GRASS itself reports the versions of e.g. wxpython?
Maybe via the g.version command?!
/Johannes
On Wed, Mar 26, 2014 at 5:11 AM, Anna Petrášová <kratochanna at gmail.com>wrote:
> On Tue, Mar 25, 2014 at 6:30 AM, Johannes Radinger <
> johannesradinger at gmail.com> wrote:
>> Hi,
>> it wanted to try out the 3D capabilities of GRASS 7. However when I
>> change to the 3d view (WxNviz) nothing is rendered, instead I get the
>> message that I should try a different depth buffer number. This procedure
>> is also mentioned in the wiki (http://grasswiki.osgeo.org/wiki/WxNviz).
>> However, I tried now all possible numbers (0,16,24,32) saved the
>> preferences and restarted the gui with the new settings but the problem
>> persists (BTW, the possible number 0 is mentioned in the wiki but not in
>> the preferences GUI).
>> I am not sure what is causing the problem in my case. Here I just need to
>> mention that I am working on a slightly special set up. GRASS is running on
>> a virtual Ubuntu machine (via VMWare) which is installed on a central multi
>> core machine (Intel® Xeon(R) CPU X5675 @ 3.07GHz × 8, Ubuntu 12.04, 32
>> bit). I connect to the virtual machine via a remote desktop connection (RDP
>> connection) from a so called thin-client.
>> My GRASS setup as follows:
>> version=7.0.svn
>> date=2014
>> revision=59321M
>> build_date=2014-03-25
>> build_platform=i686-pc-linux-gnu
>> libgis_revision=59317
>> libgis_date="2014-03-24 20:38:32 +0100 (Mon, 24 Mar 2014) "
>> proj4=4.8.0
>> gdal=1.10.0
>> geos=3.3.8
>> sqlite=3.7.9
>> Does anyone have a suggestion how to deal with that problem or how to
>> find out where the exact problem (remote connection, Ubuntu, GRASS) is
>> located?
> Could you post also wxPython version?
> Thanks
> Anna
>> Thanks,
>> Johannes
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140326/597584b9/attachment.html>
