[GRASS-user] [GRASS-dev] Problems 3D rendering with WxNviz (Ubuntu)
Anna Petrášová
kratochanna at gmail.com
Tue Mar 25 21:11:26 PDT 2014
On Tue, Mar 25, 2014 at 6:30 AM, Johannes Radinger <
johannesradinger at gmail.com> wrote:
> Hi,
> it wanted to try out the 3D capabilities of GRASS 7. However when I change
> to the 3d view (WxNviz) nothing is rendered, instead I get the message that
> I should try a different depth buffer number. This procedure is also
> mentioned in the wiki (http://grasswiki.osgeo.org/wiki/WxNviz).
> However, I tried now all possible numbers (0,16,24,32) saved the
> preferences and restarted the gui with the new settings but the problem
> persists (BTW, the possible number 0 is mentioned in the wiki but not in
> the preferences GUI).
> I am not sure what is causing the problem in my case. Here I just need to
> mention that I am working on a slightly special set up. GRASS is running on
> a virtual Ubuntu machine (via VMWare) which is installed on a central multi
> core machine (Intel® Xeon(R) CPU X5675 @ 3.07GHz × 8, Ubuntu 12.04, 32
> bit). I connect to the virtual machine via a remote desktop connection (RDP
> connection) from a so called thin-client.
> My GRASS setup as follows:
> version=7.0.svn
> date=2014
> revision=59321M
> build_date=2014-03-25
> build_platform=i686-pc-linux-gnu
> libgis_revision=59317
> libgis_date="2014-03-24 20:38:32 +0100 (Mon, 24 Mar 2014) "
> proj4=4.8.0
> gdal=1.10.0
> geos=3.3.8
> sqlite=3.7.9
> Does anyone have a suggestion how to deal with that problem or how to find
> out where the exact problem (remote connection, Ubuntu, GRASS) is located?
Could you post also wxPython version?
Thanks
Anna
> Thanks,
> Johannes
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140326/7ae4ba09/attachment.html>
