[GRASS-user] r.surf.contour (again)
Frank Broniewski
brfr at metrico.lu
Tue May 6 23:51:51 PDT 2014
Am 2014-05-01 15:27, schrieb Mark Seibel:
> Hi.
>> Well I am willing to give it a second try and now I wonder what I can
>> do better. Increase resolution? Leave out some contour lines?
> To speed up the process to see if the results are desirable, you could
> increase the resolution and try the add-on r.surf.nnbathy. Then decrease
> resolution if necessary and applicable.
> Mark
Thanks for the tip, I will try the add-on. Any idea what is causing the
distortion in the maps? It would interest me if it is a resolution issue
or the data itself ....
Frank
Frank BRONIEWSKI
METRICO s.à r.l.
géomètres
technologies d'information géographique
rue des Romains 36
L-5433 NIEDERDONVEN
tél.: +352 26 74 94 - 28
fax.: +352 26 74 94 99
http://www.metrico.lu
