[GRASS-user] patching maps together
Tim Southern
tim.southern at talktalk.net
Mon May 19 01:31:44 PDT 2014
Dear All,
I am trying to patch together a number of 1 km by 1 km tiles of a map whose values are either 0 or 1 (black on white background).
If I use r.patch to put 2 tiles together is appears to work fine but if however I try and patch more, even if it is two tiles of already patched tiles I get one set when patched as black background and white features and the other part as white background and black features. It appears that the second in the case of already patched data or third and subsequent in case of more than 2 tiles is inverted with 1 becoming 0 and 0 becoming 1.
I have tried reducing region to the smallest. Maps are at 0.2m resolution. I am hoping to get a 5 tile by 5 tile block
I have tried this across two different platforms (Mac OS and OpenSuse ) on the latest downloadable binary versions of GRASS.
Am I doing something wrong?
Kind regards
Tim
Tim Southern
