[GRASS-user] Renaming layers: temporary/session and permanent renaming
Anna Petrášová
kratochanna at gmail.com
Mon Nov 3 07:37:47 PST 2014
On Mon, Nov 3, 2014 at 10:18 AM, RichardCooper <richtcooper at hotmail.com>
wrote:
> After reading the wxgui guidelines, I see that the expected behaviour is a
> right click to enable a call to g.rename*. This is apparently not working
> in
> my GRASS version as noted above? I'm able to rename directly in the layer
> name, but this is temporary, and no g.rename window opens.
> *Ref: grass70_release/dist.i686-pc-linux-gnu/docs/html/wxGUI.html
> 'A right mouse click on a layer or left clicking the button to the right of
> the layer opens a dropdown menu with options to remove or rename the layer
> (g.remove, g.rename),...'
That's wrong, I changed it in the documentation. Renaming layer is
something different than renaming map. You can have the same map with
different symbology and then you can rename the layer to distinguish those
two layers.
About the naming of the options, I don't think we need to change it, it's
the same in QGIS - you can rename layer but it doesn't mean you rename the
underlying file.
Anna
> http://osgeo-org.1560.x6.nabble.com/Renaming-layers-temporary-session-and-permanent-renaming-tp5170973p5170981.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141103/7653c722/attachment-0001.html>
