[GRASS-user] A question before I embark on a programming exercise
Rainer M Krug
Rainer at krugs.de
Wed Nov 12 00:28:24 PST 2014
Thomas Adams <tea3rd at gmail.com> writes:
> All:
> I need to generate an ascii text file from a flow direction grid that
> consists of (among a couple other things that don't really matter at this
> point) for each pixel:
> (1) a unique integer identifier (1 -- N) for the pixel
> (2) the integer identifier of the downstream pixel (assuming there is ONLY
> one)
> (3) the x,y location of the pixel (presumably, the lower left corner of the
> pixel)
> has anyone already done something like this?
Well - I have done something similar, i.e. simulated water dispersal, in
a package which is at [1]. The actual function is at [1]. After reading
your mail again, it seems to be different, but it still might give you
some ideas.
Cheers,
Rainer
> It's needed (along with some header information) as an input file for a
> gridded distributed hydrologic model, identifying the flow connectivity
> from pixel to pixel for streamflow routing purposes. I have already
> formulated conceptually how to do this, but if someone has already done
> such a thing, why reinvent the wheel??
> Any help is appreciated.
> Regards,
> Tom
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Footnotes:
[1] https://github.com/rkrug/seedDisp
[1] https://github.com/rkrug/seedDisp/blob/master/R/waterDispGRASS.R
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141112/3377de68/attachment.pgp>
