[GRASS-user] Grass70 win7 r.basin
César Augusto Ramírez Franco caesarivs at gmail.com
Wed Oct 1 11:52:04 PDT 2014
Please keep the conversation on the list.
Please refer to [1] for detailed instructions on the proper way of
inputting the coordinates into the module. The pair of coordinates should
be similar as the ones used on r.water.outlet, you must tell the module
where in the map is the outlet of the basin you're trying to analyze.
[1] http://grasswiki.osgeo.org/wiki/R.basin#r.basin_for_GRASS_7
2014-10-01 12:22 GMT-05:00 José Anderson <joseandersonbatista at gmail.com>:
> C,
> I'm picking them from the vector streams from r.stream.extract it comes up
> from Grass picking points from geometry.
> I dont know what 'near' means..
> Thanks
> Em 01/10/2014 13:08, "César Augusto Ramírez Franco" <caesarivs at gmail.com>
> escreveu:
> Maybe you're picking the wrong pair of coordinates,
>> Are you picking them upstream from the basin outlet? I mean, near the
>> outlet but a little upstream
>> 2014-09-29 17:20 GMT-05:00 José Anderson <joseandersonbatista at gmail.com>:
>>> Dear all,
>>> in the addon r.basin, the help says that basin output coordinates must
>>> be picked up from some vector feature, the river network, which is
>>> generated by the addon r.stream.extract.
>>> That means I have the utm elevation raster and successfully ran
>>> r.watershed for accumulation raster on grass70/win7.
>>> However, despite the plugin get steps 1 through 4 without errors, it
>>> cannot complete the area delineation.
>>> I have tried, both, picking a utm point from point geometries and from
>>> line geometries.
>>> The message I get is:
>>> An Error has occurred.
>>> Please try with another pairs of outlet coordinates.
>>> Have anybody tried r.basin from grass70 on win7?
>>> Thanks in advance.
>>> Jose Anderson
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> *César Augusto Ramírez Franco*
>> Laboratorio de Sistemas Complejos Naturales
>> Escuela de Geociencias
>> Facultad de Ciencias
>> Universidad Nacional de Colombia - Sede Medellín
>> Teléfono: (57-4) 430 9369 - 300 459 6085
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141001/165ba27c/attachment.html>
