[GRASS-user] GRASS 71 win7
José Anderson joseandersonbatista at gmail.com
Thu Oct 9 08:00:24 PDT 2014
Markus, Margherita,
2014-10-07 11:33 GMT-03:00 Markus Neteler <neteler at osgeo.org>:
> That was an incompatibility in v.to.rast after latest improvements there.
> Fixed in r62202.
> Please update your r.basin installation and this error should be gone.
> Markus
Now I'm on GRASS71 r62210 (>62202) so v.to.rast succeeded (win7).
For now I got this 3 errors about <rast>, <data type> and <pattern> I
don't know where are from.
It is clear to me that *delineation of basin* was complete. But some
parser (I/O? SQL query?) does not work.
v.to.rast complete.
All in RAM calculation...
Reading raster map <bac_sb24zcpng3_drainage_e>...
Calculating basins using vector point map...
Writing raster map <bac_sb24zcpng3_basin>...
Delineation of basin done
ERROR: Sorry, <rast> is not a valid parameter
ERROR: Required parameter <type> not set:
        (Data type(s))
ERROR: Required parameter <pattern> not set:
        (Map name search pattern or map names separated by a
comma)
Thanks for lots of help.
