[GRASS-user] GRASS 71 win7
José Anderson joseandersonbatista at gmail.com
Thu Oct 9 08:13:24 PDT 2014
Markus,
you mean to move back to grass70, right?
2014-10-09 12:04 GMT-03:00 Markus Neteler <neteler at osgeo.org>:
> José,
> On Thu, Oct 9, 2014 at 5:00 PM, José Anderson
> <joseandersonbatista at gmail.com> wrote:
>> Markus, Margherita,
>> 2014-10-07 11:33 GMT-03:00 Markus Neteler <neteler at osgeo.org>:
>>> That was an incompatibility in v.to.rast after latest improvements there.
>>> Fixed in r62202.
> A minute ago I backported the v.to.rast to releasebranch7.
>>> Please update your r.basin installation and this error should be gone.
>>> Markus
>> Now I'm on GRASS71 r62210 (>62202) so v.to.rast succeeded (win7).
> Good. It will now do also with GRASS70svn (after updating at your end
> naturally).
>> For now I got this 3 errors about <rast>, <data type> and <pattern> I
>> don't know where are from.
> I suppose from g.[m]remove which is work in progress in trunk.
>> It is clear to me that *delineation of basin* was complete. But some
>> parser (I/O? SQL query?) does not work.
>> v.to.rast complete.
>> All in RAM calculation...
>> Reading raster map <bac_sb24zcpng3_drainage_e>...
>> Calculating basins using vector point map...
>> Writing raster map <bac_sb24zcpng3_basin>...
>> Delineation of basin done
>> ERROR: Sorry, <rast> is not a valid parameter
>> ERROR: Required parameter <type> not set:
>>         (Data type(s))
>> ERROR: Required parameter <pattern> not set:
>>         (Map name search pattern or map names separated by a
>> comma)
> Let me suggest (sorry but that's how it is) that you switch back to
> release branch in using r.basin.
> I shall help to get it running there if still anything is needed.
> The underlying g.[m]remove refactoring is still a moving target.
> Best
> Markus
