[GRASS-user] Compile GRASS GIS 7
Thomas Adams tea3rd at gmail.com
Mon Oct 13 06:51:48 PDT 2014
Stephen,
Almost seems as though there are permissions problems; are you doing this
as yourself (your login) or root? Also, what is the result of ./configure?
Very odd results!
Tom
On Mon, Oct 13, 2014 at 7:31 AM, stephen sefick <ssefick at gmail.com> wrote:
> Please let me know if y'all need anything else. Thanks for all of the help!
> GRASS GIS compilation log
> Started compilation: Mon Oct 13 08:08:20 CDT 2014
> Errors in:
> /home/USER/source/grass/grass7/tools/timer
> /home/USER/source/grass/grass7/lib/raster
> /home/USER/source/grass/grass7/lib/pngdriver
> /home/USER/source/grass/grass7/lib/psdriver
> /home/USER/source/grass/grass7/lib/htmldriver
> /home/USER/source/grass/grass7/lib/cairodriver
> /home/USER/source/grass/grass7/lib/display
> /home/USER/source/grass/grass7/lib/gtcltk
> /home/USER/source/grass/grass7/lib/form
> /home/USER/source/grass/grass7/lib/vector/diglib
> /home/USER/source/grass/grass7/lib/vector/Vlib
> /home/USER/source/grass/grass7/lib/vector/neta
> /home/USER/source/grass/grass7/lib/vector/vedit
> /home/USER/source/grass/grass7/lib/imagery
> /home/USER/source/grass/grass7/lib/cluster
> /home/USER/source/grass/grass7/lib/sites
> /home/USER/source/grass/grass7/lib/rst/interp_float
> /home/USER/source/grass/grass7/lib/lidar
> /home/USER/source/grass/grass7/lib/raster3d
> /home/USER/source/grass/grass7/lib/gpde
> /home/USER/source/grass/grass7/lib/init
> /home/USER/source/grass/grass7/lib/stats
> /home/USER/source/grass/grass7/lib/ogsf
> /home/USER/source/grass/grass7/lib/nviz
> /home/USER/source/grass/grass7/lib/temporal/t.connect
> /home/USER/source/grass/grass7/lib/manage
> /home/USER/source/grass/grass7/db/drivers/postgres
> /home/USER/source/grass/grass7/db/drivers/sqlite
> /home/USER/source/grass/grass7/db/drivers/dbf
> /home/USER/source/grass/grass7/db/drivers/ogr
> /home/USER/source/grass/grass7/db/db.columns
> /home/USER/source/grass/grass7/db/db.connect
> /home/USER/source/grass/grass7/db/db.copy
> /home/USER/source/grass/grass7/db/db.createdb
> /home/USER/source/grass/grass7/db/db.databases
> /home/USER/source/grass/grass7/db/db.describe
> /home/USER/source/grass/grass7/db/db.login
> /home/USER/source/grass/grass7/db/db.drivers
> /home/USER/source/grass/grass7/db/db.dropdb
> /home/USER/source/grass/grass7/db/db.tables
> /home/USER/source/grass/grass7/db/db.select
> /home/USER/source/grass/grass7/db/db.execute
> /home/USER/source/grass/grass7/display/d.colortable
> /home/USER/source/grass/grass7/display/d.barscale
> /home/USER/source/grass/grass7/display/d.erase
> /home/USER/source/grass/grass7/display/d.font
> /home/USER/source/grass/grass7/display/d.fontlist
> /home/USER/source/grass/grass7/display/d.colorlist
> /home/USER/source/grass/grass7/display/d.geodesic
> /home/USER/source/grass/grass7/display/d.grid
> /home/USER/source/grass/grass7/display/d.graph
> /home/USER/source/grass/grass7/display/d.his
> /home/USER/source/grass/grass7/display/d.histogram
> /home/USER/source/grass/grass7/display/d.info
> /home/USER/source/grass/grass7/display/d.labels
> /home/USER/source/grass/grass7/display/d.legend
> /home/USER/source/grass/grass7/display/d.linegraph
> /home/USER/source/grass/grass7/display/d.profile
> /home/USER/source/grass/grass7/display/d.mon
> /home/USER/source/grass/grass7/display/d.rast
> /home/USER/source/grass/grass7/display/d.path
> /home/USER/source/grass/grass7/display/d.rast.arrow
> /home/USER/source/grass/grass7/display/d.rast.num
> /home/USER/source/grass/grass7/display/d.rgb
> /home/USER/source/grass/grass7/display/d.title
> /home/USER/source/grass/grass7/display/d.rhumbline
> /home/USER/source/grass/grass7/display/d.text
> /home/USER/source/grass/grass7/display/d.vect
> /home/USER/source/grass/grass7/display/d.vect.chart
> /home/USER/source/grass/grass7/display/d.thematic.area
> /home/USER/source/grass/grass7/display/d.where
> /home/USER/source/grass/grass7/general/g.dirseps
> /home/USER/source/grass/grass7/general/g.copy
> /home/USER/source/grass/grass7/general/g.cairocomp
> /home/USER/source/grass/grass7/general/g.access
> /home/USER/source/grass/grass7/general/g.findetc
> /home/USER/source/grass/grass7/general/g.filename
> /home/USER/source/grass/grass7/general/g.findfile
> /home/USER/source/grass/grass7/general/g.gisenv
> /home/USER/source/grass/grass7/general/g.list
> /home/USER/source/grass/grass7/general/g.gui
> /home/USER/source/grass/grass7/general/g.mapset
> /home/USER/source/grass/grass7/general/g.mapsets
> /home/USER/source/grass/grass7/general/g.mkfontcap
> /home/USER/source/grass/grass7/general/g.message
> /home/USER/source/grass/grass7/general/g.mlist
> /home/USER/source/grass/grass7/general/g.mremove
> /home/USER/source/grass/grass7/general/g.pnmcomp
> /home/USER/source/grass/grass7/general/g.ppmtopng
> /home/USER/source/grass/grass7/general/g.parser
> /home/USER/source/grass/grass7/general/g.rename
> /home/USER/source/grass/grass7/general/g.tempfile
> /home/USER/source/grass/grass7/general/g.region
> /home/USER/source/grass/grass7/general/g.version
> /home/USER/source/grass/grass7/general/g.remove
> /home/USER/source/grass/grass7/general/g.proj
> /home/USER/source/grass/grass7/general/manage/lister
> /home/USER/source/grass/grass7/raster
> /home/USER/source/grass/grass7/raster3d/r3.cross.rast
> /home/USER/source/grass/grass7/raster3d/r3.gwflow
> /home/USER/source/grass/grass7/raster3d/r3.in.bin
> /home/USER/source/grass/grass7/raster3d/r3.gradient
> /home/USER/source/grass/grass7/raster3d/r3.in.ascii
> /home/USER/source/grass/grass7/raster3d/r3.info
> /home/USER/source/grass/grass7/raster3d/r3.mkdspf
> /home/USER/source/grass/grass7/raster3d/r3.mask
> /home/USER/source/grass/grass7/raster3d/r3.neighbors
> /home/USER/source/grass/grass7/raster3d/r3.out.ascii
> /home/USER/source/grass/grass7/raster3d/r3.null
> /home/USER/source/grass/grass7/raster3d/r3.in.v5d
> /home/USER/source/grass/grass7/raster3d/r3.out.v5d
> /home/USER/source/grass/grass7/raster3d/r3.out.vtk
> /home/USER/source/grass/grass7/raster3d/r3.out.bin
> /home/USER/source/grass/grass7/raster3d/r3.retile
> /home/USER/source/grass/grass7/raster3d/r3.stats
> /home/USER/source/grass/grass7/raster3d/r3.to.rast
> /home/USER/source/grass/grass7/raster3d/r3.support
> /home/USER/source/grass/grass7/raster3d/r3.timestamp
> /home/USER/source/grass/grass7/raster3d/r3.flow
> /home/USER/source/grass/grass7/vector/v.buffer
> /home/USER/source/grass/grass7/vector/v.build
> /home/USER/source/grass/grass7/vector/v.category
> /home/USER/source/grass/grass7/vector/v.build.polylines
> /home/USER/source/grass/grass7/vector/v.colors
> /home/USER/source/grass/grass7/vector/v.clean
> /home/USER/source/grass/grass7/vector/v.class
> /home/USER/source/grass/grass7/vector/v.colors.out
> /home/USER/source/grass/grass7/vector/v.db.connect
> /home/USER/source/grass/grass7/vector/v.convert
> /home/USER/source/grass/grass7/vector/v.db.select
> /home/USER/source/grass/grass7/vector/v.delaunay
> /home/USER/source/grass/grass7/vector/v.distance
> /home/USER/source/grass/grass7/vector/v.drape
> /home/USER/source/grass/grass7/vector/v.edit
> /home/USER/source/grass/grass7/vector/v.extract
> /home/USER/source/grass/grass7/vector/v.extrude
> /home/USER/source/grass/grass7/vector/v.hull
> /home/USER/source/grass/grass7/vector/v.info
> /home/USER/source/grass/grass7/vector/v.in.db
> /home/USER/source/grass/grass7/vector/v.in.ascii
> /home/USER/source/grass/grass7/vector/v.generalize
> /home/USER/source/grass/grass7/vector/v.in.dxf
> /home/USER/source/grass/grass7/vector/v.kernel
> /home/USER/source/grass/grass7/vector/v.in.sites
> /home/USER/source/grass/grass7/vector/v.kcv
> /home/USER/source/grass/grass7/vector/v.in.region
> /home/USER/source/grass/grass7/vector/v.lidar.edgedetection
> /home/USER/source/grass/grass7/vector/v.label
> /home/USER/source/grass/grass7/vector/v.lidar.correction
> /home/USER/source/grass/grass7/vector/v.mkgrid
> /home/USER/source/grass/grass7/vector/v.proj
> /home/USER/source/grass/grass7/vector/v.lidar.growing
> /home/USER/source/grass/grass7/vector/v.neighbors
> /home/USER/source/grass/grass7/vector/v.net.alloc
> /home/USER/source/grass/grass7/vector/v.net.allpairs
> /home/USER/source/grass/grass7/vector/v.net.centrality
> /home/USER/source/grass/grass7/vector/v.net.bridge
> /home/USER/source/grass/grass7/vector/v.net.components
> /home/USER/source/grass/grass7/vector/v.net.distance
> /home/USER/source/grass/grass7/vector/v.net.flow
> /home/USER/source/grass/grass7/vector/v.net.iso
> /home/USER/source/grass/grass7/vector/v.net.path
> /home/USER/source/grass/grass7/vector/v.net.salesman
> /home/USER/source/grass/grass7/vector/v.net.connectivity
> /home/USER/source/grass/grass7/vector/v.net.spanningtree
> /home/USER/source/grass/grass7/vector/v.net.steiner
> /home/USER/source/grass/grass7/vector/v.net.visibility
> /home/USER/source/grass/grass7/vector/v.net.timetable
> /home/USER/source/grass/grass7/vector/v.lrs/v.lrs.segment
> /home/USER/source/grass/grass7/vector/v.lrs/v.lrs.create
> /home/USER/source/grass/grass7/vector/v.normal
> /home/USER/source/grass/grass7/vector/v.out.dxf
> /home/USER/source/grass/grass7/vector/v.out.ascii
> /home/USER/source/grass/grass7/vector/v.out.pov
> /home/USER/source/grass/grass7/vector/v.lrs/v.lrs.label
> /home/USER/source/grass/grass7/vector/v.out.svg
> /home/USER/source/grass/grass7/vector/v.outlier
> /home/USER/source/grass/grass7/vector/v.lrs/v.lrs.where
> /home/USER/source/grass/grass7/vector/v.out.vtk
> /home/USER/source/grass/grass7/vector/v.overlay
> /home/USER/source/grass/grass7/vector/v.perturb
> /home/USER/source/grass/grass7/vector/v.split
> /home/USER/source/grass/grass7/vector/v.parallel
> /home/USER/source/grass/grass7/vector/v.qcount
> /home/USER/source/grass/grass7/vector/v.random
> /home/USER/source/grass/grass7/vector/v.patch
> /home/USER/source/grass/grass7/vector/v.rectify
> /home/USER/source/grass/grass7/vector/v.sample
> /home/USER/source/grass/grass7/vector/v.reclass
> /home/USER/source/grass/grass7/vector/v.select
> /home/USER/source/grass/grass7/vector/v.surf.bspline
> /home/USER/source/grass/grass7/vector/v.support
> /home/USER/source/grass/grass7/vector/v.surf.idw
> /home/USER/source/grass/grass7/vector/v.transform
> /home/USER/source/grass/grass7/vector/v.segment
> /home/USER/source/grass/grass7/vector/v.timestamp
> /home/USER/source/grass/grass7/vector/v.to.3d
> /home/USER/source/grass/grass7/vector/v.surf.rst
> /home/USER/source/grass/grass7/vector/v.to.db
> /home/USER/source/grass/grass7/vector/v.to.rast
> /home/USER/source/grass/grass7/vector/v.to.rast3
> /home/USER/source/grass/grass7/vector/v.to.points
> /home/USER/source/grass/grass7/vector/v.type
> /home/USER/source/grass/grass7/vector/v.univar
> /home/USER/source/grass/grass7/vector/v.what
> /home/USER/source/grass/grass7/vector/v.voronoi
> /home/USER/source/grass/grass7/vector/v.what.rast
> /home/USER/source/grass/grass7/vector/v.vect.stats
> /home/USER/source/grass/grass7/vector/v.out.ogr
> /home/USER/source/grass/grass7/vector/v.vol.rst
> /home/USER/source/grass/grass7/vector/v.in.ogr
> /home/USER/source/grass/grass7/vector/v.external
> /home/USER/source/grass/grass7/vector/v.external.out
> /home/USER/source/grass/grass7/misc/m.cogo
> /home/USER/source/grass/grass7/misc/m.measure
> /home/USER/source/grass/grass7/misc/m.nviz.script
> /home/USER/source/grass/grass7/misc/m.transform
> /home/USER/source/grass/grass7/misc/m.nviz.image
> /home/USER/source/grass/grass7/imagery/i.albedo
> /home/USER/source/grass/grass7/imagery/i.aster.toar
> /home/USER/source/grass/grass7/imagery/i.biomass
> /home/USER/source/grass/grass7/imagery/i.atcorr
> /home/USER/source/grass/grass7/imagery/i.cca
> /home/USER/source/grass/grass7/imagery/i.eb.evapfr
> /home/USER/source/grass/grass7/imagery/i.cluster
> /home/USER/source/grass/grass7/imagery/i.eb.eta
> /home/USER/source/grass/grass7/imagery/i.eb.h_SEBAL01
> /home/USER/source/grass/grass7/imagery/i.eb.netrad
> /home/USER/source/grass/grass7/imagery/i.eb.soilheatflux
> /home/USER/source/grass/grass7/imagery/i.evapo.mh
> /home/USER/source/grass/grass7/imagery/i.evapo.pm
> /home/USER/source/grass/grass7/imagery/i.evapo.pt
> /home/USER/source/grass/grass7/imagery/i.emissivity
> /home/USER/source/grass/grass7/imagery/i.evapo.time
> /home/USER/source/grass/grass7/imagery/i.gensig
> /home/USER/source/grass/grass7/imagery/i.find
> /home/USER/source/grass/grass7/imagery/i.his.rgb
> /home/USER/source/grass/grass7/imagery/i.landsat.toar
> /home/USER/source/grass/grass7/imagery/i.gensigset
> /home/USER/source/grass/grass7/imagery/i.latlong
> /home/USER/source/grass/grass7/imagery/i.group
> /home/USER/source/grass/grass7/imagery/i.maxlik
> /home/USER/source/grass/grass7/imagery/i.rectify
> /home/USER/source/grass/grass7/imagery/i.landsat.acca
> /home/USER/source/grass/grass7/imagery/i.modis.qc
> /home/USER/source/grass/grass7/imagery/i.sunhours
> /home/USER/source/grass/grass7/imagery/i.rgb.his
> /home/USER/source/grass/grass7/imagery/i.smap
> /home/USER/source/grass/grass7/imagery/i.target
> /home/USER/source/grass/grass7/imagery/i.pca
> /home/USER/source/grass/grass7/imagery/i.vi
> /home/USER/source/grass/grass7/ps/ps.map
> /home/USER/source/grass/grass7/scripts/d.correlate
> /home/USER/source/grass/grass7/scripts/d.out.file
> /home/USER/source/grass/grass7/scripts/d.polar
> /home/USER/source/grass/grass7/scripts/d.rast.leg
> /home/USER/source/grass/grass7/scripts/d.redraw
> /home/USER/source/grass/grass7/scripts/d.shadedmap
> /home/USER/source/grass/grass7/scripts/db.dropcolumn
> /home/USER/source/grass/grass7/scripts/d.vect.thematic
> /home/USER/source/grass/grass7/scripts/db.droptable
> /home/USER/source/grass/grass7/scripts/db.in.ogr
> /home/USER/source/grass/grass7/scripts/db.out.ogr
> /home/USER/source/grass/grass7/scripts/db.test
> /home/USER/source/grass/grass7/scripts/db.univar
> /home/USER/source/grass/grass7/scripts/g.manual
> /home/USER/source/grass/grass7/scripts/g.extension.all
> /home/USER/source/grass/grass7/scripts/i.image.mosaic
> /home/USER/source/grass/grass7/scripts/i.in.spotvgt
> /home/USER/source/grass/grass7/scripts/i.oif
> /home/USER/source/grass/grass7/scripts/i.colors.enhance
> /home/USER/source/grass/grass7/scripts/i.spectral
> /home/USER/source/grass/grass7/scripts/i.tasscap
> /home/USER/source/grass/grass7/scripts/m.proj
> /home/USER/source/grass/grass7/scripts/r.blend
> /home/USER/source/grass/grass7/scripts/r.buffer.lowmem
> /home/USER/source/grass/grass7/scripts/r.colors.stddev
> /home/USER/source/grass/grass7/scripts/r.fillnulls
> /home/USER/source/grass/grass7/scripts/r.in.aster
> /home/USER/source/grass/grass7/scripts/d.rast.edit
> /home/USER/source/grass/grass7/scripts/r.in.srtm
> /home/USER/source/grass/grass7/scripts/r.grow
> /home/USER/source/grass/grass7/scripts/r.mask
> /home/USER/source/grass/grass7/scripts/r.in.wms
> /home/USER/source/grass/grass7/scripts/r.out.xyz
> /home/USER/source/grass/grass7/scripts/r.plane
> /home/USER/source/grass/grass7/scripts/r.reclass.area
> /home/USER/source/grass/grass7/scripts/r.pack
> /home/USER/source/grass/grass7/scripts/r.rgb
> /home/USER/source/grass/grass7/scripts/r.tileset
> /home/USER/source/grass/grass7/scripts/r.unpack
> /home/USER/source/grass/grass7/scripts/v.centroids
> /home/USER/source/grass/grass7/scripts/v.convert.all
> /home/USER/source/grass/grass7/scripts/v.build.all
> /home/USER/source/grass/grass7/scripts/v.db.addcolumn
> /home/USER/source/grass/grass7/scripts/r3.in.xyz
> /home/USER/source/grass/grass7/scripts/v.db.addtable
> /home/USER/source/grass/grass7/scripts/i.pansharpen
> /home/USER/source/grass/grass7/scripts/v.db.join
> /home/USER/source/grass/grass7/scripts/v.db.droptable
> /home/USER/source/grass/grass7/scripts/v.db.dropcolumn
> /home/USER/source/grass/grass7/scripts/v.db.droprow
> /home/USER/source/grass/grass7/scripts/v.db.renamecolumn
> /home/USER/source/grass/grass7/scripts/v.db.reconnect.all
> /home/USER/source/grass/grass7/scripts/v.db.update
> /home/USER/source/grass/grass7/scripts/v.db.univar
> /home/USER/source/grass/grass7/scripts/v.dissolve
> /home/USER/source/grass/grass7/scripts/v.in.geonames
> /home/USER/source/grass/grass7/scripts/v.in.e00
> /home/USER/source/grass/grass7/scripts/v.in.gns
> /home/USER/source/grass/grass7/scripts/v.in.lines
> /home/USER/source/grass/grass7/scripts/v.in.wfs
> /home/USER/source/grass/grass7/scripts/v.in.mapgen
> /home/USER/source/grass/grass7/scripts/v.rast.stats
> /home/USER/source/grass/grass7/scripts/v.out.gps
> /home/USER/source/grass/grass7/scripts/v.report
> /home/USER/source/grass/grass7/scripts/v.pack
> /home/USER/source/grass/grass7/scripts/v.to.lines
> /home/USER/source/grass/grass7/scripts/v.what.vect
> /home/USER/source/grass/grass7/scripts/v.unpack
> /home/USER/source/grass/grass7/scripts/wxpyimgview
> /home/USER/source/grass/grass7/scripts/v.krige
> /home/USER/source/grass/grass7/temporal/t.connect
> /home/USER/source/grass/grass7/temporal/t.create
> /home/USER/source/grass/grass7/temporal/t.support
> /home/USER/source/grass/grass7/temporal/t.topology
> /home/USER/source/grass/grass7/temporal/t.list
> /home/USER/source/grass/grass7/temporal/t.info
> /home/USER/source/grass/grass7/temporal/t.merge
> /home/USER/source/grass/grass7/temporal/t.sample
> /home/USER/source/grass/grass7/temporal/t.unregister
> /home/USER/source/grass/grass7/temporal/t.register
> /home/USER/source/grass/grass7/temporal/t.remove
> /home/USER/source/grass/grass7/temporal/t.rast.accumulate
> /home/USER/source/grass/grass7/temporal/t.rast.accdetect
> /home/USER/source/grass/grass7/temporal/t.rast.aggregate.ds
> /home/USER/source/grass/grass7/temporal/t.rast.colors
> /home/USER/source/grass/grass7/temporal/t.rast.univar
> /home/USER/source/grass/grass7/temporal/t.rast.to.rast3
> /home/USER/source/grass/grass7/temporal/t.rast.list
> /home/USER/source/grass/grass7/temporal/t.rast.mapcalc
> /home/USER/source/grass/grass7/temporal/t.rast.mapcalc2
> /home/USER/source/grass/grass7/temporal/t.rast.neighbors
> /home/USER/source/grass/grass7/temporal/t.rast.series
> /home/USER/source/grass/grass7/temporal/t.rast.export
> /home/USER/source/grass/grass7/temporal/t.rast.out.vtk
> /home/USER/source/grass/grass7/temporal/t.rast.import
> /home/USER/source/grass/grass7/temporal/t.rast.gapfill
> /home/USER/source/grass/grass7/temporal/t.rast.extract
> /home/USER/source/grass/grass7/temporal/t.rast3d.list
> /home/USER/source/grass/grass7/temporal/t.rast3d.extract
> /home/USER/source/grass/grass7/temporal/t.rast3d.mapcalc
> /home/USER/source/grass/grass7/temporal/t.select
> /home/USER/source/grass/grass7/temporal/t.rast3d.univar
> /home/USER/source/grass/grass7/temporal/t.rast3d.mapcalc2
> /home/USER/source/grass/grass7/temporal/t.rename
> /home/USER/source/grass/grass7/temporal/t.vect.db.select
> /home/USER/source/grass/grass7/temporal/t.snap
> /home/USER/source/grass/grass7/temporal/t.vect.list
> /home/USER/source/grass/grass7/temporal/t.vect.extract
> /home/USER/source/grass/grass7/temporal/t.shift
> /home/USER/source/grass/grass7/temporal/t.vect.export
> /home/USER/source/grass/grass7/temporal/t.vect.mapcalc
> /home/USER/source/grass/grass7/temporal/t.vect.import
> /home/USER/source/grass/grass7/temporal/t.vect.what.strds
> /home/USER/source/grass/grass7/temporal/t.vect.observe.strds
> /home/USER/source/grass/grass7/temporal/t.vect.univar
> /home/USER/source/grass/grass7/visualization/xganim
> /home/USER/source/grass/grass7/visualization/wximgview
> /home/USER/source/grass/grass7/visualization/ximgview
> /home/USER/source/grass/grass7/visualization/nviz
> /home/USER/source/grass/grass7/man
> In case of errors please change into the directory with error and run
> 'make'.
> If you get multiple errors, you need to deal with them in the order they
> appear in the error log. If you get an error building a library, you will
> also get errors from anything which uses the library.
> Finished compilation: Mon Oct 13 08:09:10 CDT 2014
> make: *** [default] Error 1
> /home/USER/source/grass/grass7/bin.x86_64-unknown-linux-gnu/grass70
> make install-check-built
> make[1]: Entering directory `/home/USER/source/grass/grass7'
> make[1]: Leaving directory `/home/USER/source/grass/grass7'
> make install-check-parent
> make install-check-writable
> make install-check-prefix
> make real-install
> tar cBCf /home/USER/source/grass/grass7/dist.x86_64-unknown-linux-gnu - .
> | tar xBCf /usr/local/grass-7.0.svn - 2>/dev/null
> rm /usr/local/grass-7.0.svn/grass70.tmp
> make /usr/local/bin/grass70
> make[2]: Entering directory `/home/USER/source/grass/grass7'
> sed -e 's#'@GISBASE@'#'/usr/local/grass-7.0.svn'#g' \
>     -e 's#'@LD_LIBRARY_PATH_VAR@'#'LD_LIBRARY_PATH'#g' \
>     -e 's#'@CONFIG_PROJSHARE@'#'/usr/share/proj'#g' \
>  /home/USER/source/grass/grass7/dist.x86_64-unknown-linux-gnu/grass70.tmp >
> chmod a+x /usr/local/bin/grass70
> make[2]: Leaving directory `/home/USER/source/grass/grass7'
> rm /usr/local/grass-7.0.svn/etc/fontcap
> rm: cannot remove `/usr/local/grass-7.0.svn/etc/fontcap': No such file or
> directory
> make[1]: [real-install] Error 1 (ignored)
> make /usr/local/grass-7.0.svn/etc/fontcap
> make[2]: *** No rule to make target
> `/home/USER/source/grass/grass7/dist.x86_64-unknown-linux-gnu/etc/fontcap',
> needed by `/usr/local/grass-7.0.svn/etc/fontcap'.  Stop.
> make[1]: *** [real-install] Error 2
> make: *** [install] Error 2
> On Sat, Oct 11, 2014 at 6:22 PM, Rich Shepard <rshepard at appl-ecosys.com>
> wrote:
>> On Sat, Oct 11, 2014 at 9:42 AM, stephen sefick <ssefick at gmail.com>
>> wrote:
>>  I am using the instructions here:
>>> http://grasswiki.osgeo.org/wiki/Compile_and_Install
>>> To compile GRASS 7 latest source code with svn up for SL Linux 6.5.
>>  I have errors in what seem to be all directories. I will provide the
>>> transcript of make if necessary.
>> Stephen,
>>   I've had that on occassion and it turned out to be conflicts between
>> wxGTK
>> and wxPython. Currently installed are wxGTK-2.8.12-i486-3_SBo and
>> wxPython-3.0.1.1-i486-1_SBo, no wxGTK3.
>>   If you have no such conflicts, then perhaps a message with the errors
>> (from the last back a few) will help.
>> Rich
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Stephen Sefick
> Auburn University
> Biological Sciences
> 331 Funchess Hall
> Auburn, Alabama
> 36849
> sas0025 at auburn.edu
> http://www.auburn.edu/~sas0025
> Let's not spend our time and resources thinking about things that are so
> little or so large that all they really do for us is puff us up and make us
> feel like gods.  We are mammals, and have not exhausted the annoying little
> problems of being mammals.
>                                 -K. Mullis
> "A big computer, a complex algorithm and a long time does not equal
> science."
>                               -Robert Gentleman
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141013/2600a45d/attachment-0001.html>
