[GRASS-user] Fwd: my first script
Anna Petrášová kratochanna at gmail.com
Tue Oct 14 17:40:51 PDT 2014
Forwarded back to mailing list:
---------- Forwarded message ----------
Date: Tue, Oct 14, 2014 at 8:22 PM
Subject: Re: [GRASS-user] my first script
To: Anna Petrášová <kratochanna at gmail.com>
Cara Anna,
my script is ok with v.in.ascii
but with v.in.lines return this error
C:/Program Files/GRASS GIS 6.4.4/scripts/v.in.lines: line
126: v.in.mapgen: command not found
(Wed Oct 15 02:00:03 2014) Comando terminato (4 sec)
where 's the problem now?
how do I make a list of points (x, y) in a polyline if v.in.lines is ko!
ciao
2014-10-15 1:54 GMT+02:00 Anna Petrášová <kratochanna at gmail.com>:
> On Tue, Oct 14, 2014 at 7:37 PM, Giuliano Urgeghe <giuliano.u at gmail.com>
> wrote:
>> Ciao Anna
>> problema risolto
>> usando ','
> I guess this means success:)
> Best,
> Anna
>> GRAZIE
>> 2014-10-15 0:10 GMT+02:00 Giuliano Urgeghe <giuliano.u at gmail.com>:
>>> just to say that I also tried with fs=','
>>> and I had the same error:
>>> "output" non Š riconosciuto come comando interno o esterno,
>>>  un programma eseguibile o un file batch.
>>> which module is contained in this response string?
>>> 2014-10-14 23:19 GMT+02:00 Giuliano Urgeghe <giuliano.u at gmail.com>:
>>>> Hi Anna,
>>>> thanks for your interest
>>>> I checked
>>>> my fs in the input is '|'
>>>> the word 'output' in grass.run.command's argument is not known
>>>> is an error in core.py? or is a bug in windows executing?
>>>> I don't find solution
>>>> Bye
>>>> Giuliano
>>>> 2014-10-14 3:45 GMT+02:00 Anna Petrášová <kratochanna at gmail.com>:
>>>>> On Mon, Oct 13, 2014 at 5:53 PM, Giuliano Urgeghe <
>>>>> giuliano.u at gmail.com> wrote:
>>>>>> Hi,
>>>>>> thanks for your help.
>>>>>> At moment I have another problem
>>>>>> in my script I have this line:
>>>>>> #    grass.run_command('v.in.lines', overwrite=True, input =
>>>>>> output_esond_txt , output = output_esond_gis, fs='|')
>>>>>>     grass.run_command('v.in.ascii', overwrite=True, format= 'point',
>>>>>> fs='|', input = output_esond_txt, output = output_esond_gis )
>>>>>> output is:
>>>>> Not sure, but could you try use different separator
>>>>> fs=',', input = output_esond_txt, output = output_esond_gis )
>>>>> or, since | is a default, not using it in the command at all?
>>>>> grass.run_command('v.in.ascii', overwrite=True, format= 'point', input
>>>>> Anna
>>>>>> why?
>>>>>> I have made many attempts whith grass6.4.2  grass6.4.3  grass6.4.4
>>>>>> in windows Vista
>>>>>> you know the problem?
>>>>>> thanks in advance
>>>>>> Giuliano
>>>>>> 2014-10-13 7:43 GMT+02:00 Johannes Radinger <
>>>>>> johannesradinger at gmail.com>:
>>>>>>> Hi,
>>>>>>> It seems to raise an error related to the flag(s) you are specifying
>>>>>>> in oneof your grass modules you are using in your script. Flags in grass
>>>>>>> python scripts should be used like: flags="a" or for two flags: flags="ab".
>>>>>>> Note this does not need a "-" like in the bash command.
>>>>>>> Best,
>>>>>>> /johannes
>>>>>>> -------- Original message --------
>>>>>>> From: Giuliano Urgeghe <giuliano.u at gmail.com>
>>>>>>> Date: 13/10/2014 02:44 (GMT+01:00)
>>>>>>> To: grass-user at lists.osgeo.org
>>>>>>> Subject: [GRASS-user] my first script
>>>>>>> Hi all,
>>>>>>> I have my first script in python for grass
>>>>>>> but when I launch it on windows vista for grass 6.4.2 in quantum gis
>>>>>>> I have this output:
>>>>>>> File "C:\PROGRA~1\QUANTU~3\apps\grass\grass-6.4.2\etc\pyth
>>>>>>> on\grass\script\core.py", line 189, in run_command
>>>>>>>     ps = start_command(*args, **kwargs)
>>>>>>> on\grass\script\core.py", line 167, in start_command
>>>>>>>     args = make_command(prog, flags, overwrite, quiet,
>>>>>>> verbose, **options)
>>>>>>> on\grass\script\core.py", line 124, in make_command
>>>>>>>     raise ScriptError("'-' is not a valid flag")
>>>>>>> grass.script.core.ScriptError: "'-' is not a valid flag"
>>>>>>> someone know this problem?
>>>>>>> thanks in advance
>>>>>>> Giuliano
>>>>>> _______________________________________________
>>>>>> grass-user mailing list
>>>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>>> Ing. Giuliano Urgeghe
>>>> Via Prunizzedda 61 - 07100 Sassari
>>>> tel. 3283268186
>>>> Cerca di non inviarmi files .doc, .xls, .ppt, .dwg
>>>> Preferisco formati liberi.
>>>> Please try to avoid to send me .doc, .xls, .ppt, .dwg files.
>>>> I prefer free formats.
>>>> http://it.wikipedia.org/wiki/Formato_aperto
>>>> http://en.wikipedia.org/wiki/Open_format
>>> tel. 3283268186
>> tel. 3283268186
tel. 3283268186
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141014/6b2e7463/attachment-0001.html>
