[GRASS-user] Fwd: my first script
Markus Neteler neteler at osgeo.org
Tue Oct 14 23:04:58 PDT 2014
> my script is ok with v.in.ascii
>> On Tue, Oct 14, 2014 at 7:37 PM, Giuliano Urgeghe <giuliano.u at gmail.com>
>>> problema risolto
>>> usando ','
>> I guess this means success:)
@devs: this is another confirmation that pipe as delimiter seems to
cause problems on Windows (see other issue in v.in.geonames recently
reported).
> but with v.in.lines return this error
> C:/Program Files/GRASS GIS 6.4.4/scripts/v.in.lines: line
> 126: v.in.mapgen: command not found
> (Wed Oct 15 02:00:03 2014) Comando terminato (4 sec)
> where 's the problem now?
It seems that v.in.mapgen (a script) is not properly called by
v.in.lines (also a script) on Windows.
> how do I make a list of points (x, y) in a polyline if v.in.lines is ko!
Consider to use GRASS 7 where these script issues on Windows have been resolved.
Markus
