[GRASS-user] fatal error: 'libintl.h' file not found (OSX)
Markus Neteler
neteler at osgeo.org
Tue Oct 14 23:08:12 PDT 2014
On Wed, Oct 15, 2014 at 1:57 AM, Michael Barton <Michael.Barton at asu.edu> wrote:
> I do bundle it in my GRASS binaries.
> My point is that there is no functional reason that internationalization (which is otherwise optional in configuration for GRASS) should be needed to compile r.stream. extract.
But don't you compile with --with-nls support? Then it is needed as it
is for most other commands which come with gettext enabled messages.
Markus
